Casio FP-1000/1100 y FP-6000
Giorgos
Agradecido : 4 veces
Re: Casio FP-1000/1100 y FP-6000
Mensajepor Giorgos » 15 Feb 2019 18:58
dont forget, ENTER key (Golf asks for it) in Takedo Emulator is probably control+w :)
Nodoyuna
Agradecido : 126 veces
Mensajepor Nodoyuna » 15 Feb 2019 19:35
CasioFP escribió:
por cierto, tiene un conector para el video que no he visto en ninguna parte :
tiene ocho contactos, pero organizados en dos hileras de 3+1.
Abri el conector por si se encontraba ese circuito SN dentro, paro no:
Buenas, ¿se podrían hacer adaptadores de este tipo de cable a euroconector, por ejemplo?
Agradecido : 3514 veces
Agradecimiento recibido: 3953 veces
Mensajepor ron » 15 Feb 2019 19:40
reflotazo, habrá que echar un ojo.
Let's take a look. Also, You could go through the presentation thread and we can know a little more about your hobby
Giorgos
Casio FP-1000/1100 software
Mensajepor Giorgos » 17 Feb 2019 14:25
If anyone can share additional software for the Casio, I'd be more than grateful.
I am willing to pay for disks and shipping as well.
Thanks!
WhatIsAMan
Agradecido : 367 veces
Agradecimiento recibido: 429 veces
Mensajepor WhatIsAMan » 17 Feb 2019 17:44
Greetings Giorgos,
Wow, I think that may pass as the biggest necroposting in history... -rofl
I recommend you to write a new thread in the introductions ("Presentaciones" in Spanish) category as it's an habit on this forum. It may also be good as people here may know a little bit more about your particular interests.
I don't have a Casio, but I know that having a rare system and "feed" it with software can be difficult as it may be unavailable. Your contribution is welcome, it may help some people around here. -drinks
Thank you very much and looking forward for your public (and awaited) introduction.
P.S. Don't be shy! -thumbup
Giorgos
Mensajepor Giorgos » 17 Feb 2019 18:27
Alright, I will. Thanks!
I was always kind like this, never shy ;)
Agradecido : 839 veces
Agradecimiento recibido: 1818 veces
Mensajepor jltursan » 18 Feb 2019 19:03
Nodoyuna escribió:Buenas, ¿se podrían hacer adaptadores de este tipo de cable a euroconector, por ejemplo?
Todo se puede hacer pero no fácilmente. Esta conexión lleva sincronismos separados y señales TTL, el euroconector necesita el compuesto y sus niveles son analógicos. Si que es muy fácil de conectar a un monitor 1084 de Commodore o sus primos CGA que ofrecen un conexionado similar.
Nodoyuna
Mensajepor Nodoyuna » 18 Feb 2019 19:27
Gracias por la respuesta...
¿Y conversión a VGA?
Mensajepor jltursan » 18 Feb 2019 21:46
Peor, de digital a analógico y frecuencias dobladas (de 15Khz a 31Khz). También se puede pero aún con más circuitería...
Nodoyuna
Mensajepor Nodoyuna » 18 Feb 2019 22:44
jltursan escribió:Peor, de digital a analógico y frecuencias dobladas (de 15Khz a 31Khz). También se puede pero aún con más circuitería...
Jejejeje... Me estoy luciendo yo hoy :)
Entonces, o te haces con el monitor original, o un adaptador a CGA o al Commodore 1084S...
Agradecido : 6234 veces
Agradecimiento recibido: 2413 veces
Mensajepor minter » 19 Feb 2019 13:57
Hay una cosa que hay que estar atentos. Las fotos de este hilo cuelgan de una carpeta de Picasa.
Parece ser que para el 2 de abril de este año, se cierra Google+. Dice que no va a afectar a las fotos y vídeos guardados aunque la verdad. no me fío.
Voy a copiar lo que vea mas importante o digno de guardar dentro de una carpeta del Wiki, para que no se pierda.
Pero no voy a duplicar todo en el WIki, que luego los admins me pueden reñir por comer el almacenamiento por un "por si acaso".
Así que recomiendo los que tengan Casios, se hagan una copia de lo que necesiten y que no esté en la red.
(No me fío de gugle y de sus cambios unilaterales)
Mensajepor jltursan » 19 Feb 2019 19:01
Buf, eso me recuerda a Imageshack, vaya pufo que hubo con sus imágenes... -banghead
Lo del monitor original es muy poco apañao; pero encontrar los 1084 o relativos no es complicado aunque se han subido a la parra (como todo realmente). Los adaptadores pueden ser la mejor opción, te pillas un Gonbes y puedes apañar cómodamente el asunto.
OldComputersES
Mensajepor OldComputersES » 11 Feb 2023 08:52
CasioFP escribió:Hola,
Vuelvo con unos documentitos mas escaneados para la serie de ordenadores Casio.
Esta vez se tratan de los Service Manual, que han sido utilizados por los importadores de estos equipos para repararlos.
Tuve muchisima suerte al poder quedarme con estos manuales, regalados por el importador francés Lansay al momento en el que cesaba por completo de vender los Casio FP en Francia, a finales de los anos 80 (algo por 1987 o 1988, no recuerdo precisamente).
Todo este tiempo estuve guardandolos con sumo cuidado por si me hiciera falta algun dia, pero tuve suerte, mis Casios siguen funcionando unos 25 anos despues !! Y sigo tan atonito de no haber visto estos manuales por ningun sitio. Ojalà y le sirvan a alguién que entienda (yo de électronica, nada...), sea un retromuseo o un miembro de Retrowiki.
Aqui estan los manuales:
Casio FP-1100 Service Manual (111 pàg.)
https://dl-web.dropbox.com/get/Casio%20FP-1100%20PDF%20Manuals/Casio%20FP-1000%20Series%20Service%20Manual.pdf?w=9dc38b9d
Casio FP-200 Service Manual (67 pàg.)
https://dl-web.dropbox.com/get/Casio%20FP-1100%20PDF%20Manuals/Casio%20FP-200%20Service%20Manual.pdf?w=c0a581ff
@Jepalza, si le entiendes a electronica, con este manual deberias poder hacer arrancar el Casio FP-200 que te prometi ;)
Mensaje para Ron : gracias por el trabajal en este foro, y a los muchos contribuyentes - por cierto, aqui me siento MUY bien, y sigo aprendiendo cantidad de cosas acerca de los Sinclair Spectrum, Dragon y otros mas. Y esto da gusto !!!
Conforme pueda encontrar tiempo -que es muy escaso como ya saben- seguire escaneando los demas manuales Casio que tengo si hay interés -
Joscelyn
Hola, tenemos un casio fp-1000 que no funciona, y estamos interesados en el Service Manual que publicaste en este hilo, pero el enlace es a una carpeta de dropbox y ya no está disponible. ¿nos podrías facilitar una copia?
