ZEsarUX 6.1 RC
chernandezba
ZEsarUX 6.1 RC
Mensajepor chernandezba » 14 Abr 2018 08:48
Hola
He subido una nueva versión beta de ZEsarUX. Esta es ZEsarUX 6.1 RC, y la siguiente version ya será la estable final :)
Se puede descargar desde:
https://github.com/chernandezba/zesarux/releases
Puedes ver la lista completa de cambios aqui:
https://github.com/chernandezba/zesarux ... /Changelog
Los siguientes son los cambios desde la última beta de Marzo:
Added ZX-Evolution BaseConf emulation (experimental)
Added a fast spectrum core (with some features disabled) just for slow devices, like Raspberry Pi 1/Zero. Now ZEsarUX is playable on RPi1/Zero again!
Added setting to save spectrum screen to pbm file (black&white)
Added a setting to dump ram contents to file when exiting ZEsarUX, ideal to run automatic tests
Improved debugging:
* added cpu-step-over function on debug menu (was already available from ZRCP)
* added function to write byte to file on ZEsarUX hardware debug ports
Improved ZRCP:
* when a breakpoint is fired on cpu-step-mode, the breakpoint condition is shown on ZRCP
Improved file viewer from file utilities:
* conversion utility
Improved TSConf emulation:
* added TR-DOS emulation support
Improved menu interface:
* added a setting to limit menu event: enabling it you should press the menu key 3 times in a second to open the menu
* added a setting to hide directories from file selector menus, useful when you don't want the user to be able to navigate the filesystem
Improved TBBlue emulation:
* Added Copper
* Added almost all next extended opcodes
* Added a setting to start TBBlue directly to a 48 rom but with all the Next features enabled, useful for fast snapshot loading
Fixed panic screen: now it is shown on all machines. New design. I hope you never see it ;)
Fixed bug on Z80 cpu core, iff2 was not being reset to 0 when firing an interrupt, so reading it by using LD A,R and LD A,I affected many demos
César
ZEsarUX
