BBC Micro a la coleccion
Agradecido : 268 veces
Mensajepor Nandove » 29 Sep 2017 09:23
Pues ya tenia uno, pero resulta que era un BBC micro version alemana que internamente era bastante diferente al original.... asi que se lo pase a un amigo y me pille otro british:
Como mola su modo de 80 col. -shock -drinks
EDIT:
Y el hermanito pequeño tambien!
Ampliacion casi-necesaria:
http://www.zeridajh.org/hardware/gosdc/snapshots.htm
Agradecido : 2057 veces
Agradecimiento recibido: 883 veces
Re: BBC Micro a la coleccion
Mensajepor minter » 29 Sep 2017 09:41
Nandove escribió:Como mola su modo de 80 col. -shock -drinks
80 columnas y de trazo grueso. -shock
Como se nota que estos ya estaban orientados al CP/M
Muy bonito! -thumbup
Mensajepor Nandove » 29 Sep 2017 09:55
Available Modes
The available display modes and the resolution of which they are capable are listed below. As described later in the Drawing on The Screen sub-section, none of the PC display formats available with any of the display adapters offer identical resolution to the BBC Micro and complete compatibility is not possible. However, in order to make BBCBASIC(86) as compatible as possible with the BBC Micro, the original BBC Micro modes have been mapped on to the PC mode with the closest attribute match. As a consequence, a number of the modes have identical attributes.
Mode Graphics (pixels) Logical Colours Text (chars)
0 640x200 2 colour display 80x25
1 320x200 4 colour display 40x25
2 Same as mode 1
3 None 16 colour text only 80x25
4 320x200 4 colour display 40x25
5 Same as mode 4
6 None 16 colour text only 40x25
7 None Monochrome text only 80x25
Viewdata emulation 40x25
8 640x200 16 colour 80x25
9 320x200 16 colour 40x25
10 Same as mode 9
11 Same as mode 3
12 Same as mode 9
13 Same as mode 9
14 Same as mode 6
15 640x350 monochrome display 80x25
16 640x350 16 colour 80x25 or
80x43
17 Reserved for expansion.
18 640x480 16 colour 80x30 or
80x60
This table indicates the number of logical colours available in each display mode. As described in The Palette sub-section, the number of physical colours available depends upon the display adapter fitted.
Modes 1, 2, 4 and 5 are identical except that, when using the NTSC composite video output, modes 4 and 5 cause the colour subcarrier to be suppressed.
Several display adapters with widely differing capabilities are available for the PC. Because of this difference in capabilities, the display modes available to BBCBASIC(86) depend upon the display adapter fitted to your computer.
Modes 0 to 6 are available if either a CGA, EGA or VGA are fitted and a standard CGA (or VGA) monitor is connected.
Viewdata mode 7 is available if an EGA or VGA is fitted, an EGA (or VGA) monitor is connected and MODE7.COM has been loaded. See the Annex entitled Viewdata MODE 7 for further details.
Normal mode 7 is available if an MDA, EGA or VGA is fitted and a monochrome (or VGA) monitor is connected.
Modes 8 to 14 and are available if an EGA or VGA is fitted and a standard CGA (or VGA) monitor is connected.
Mode 15 is available if an EGA or VGA is fitted and a monochrome (or VGA) monitor is connected.
Mode 16 is available is an EGA or VGA is fitted and an enhanced monitor capable of switching to different line scan frequencies (or a VGA monitor) is connected. In this mode the text resolution is 80x25 when the text is written at the text cursor position (VDU 4). If the text is written at the graphics cursor position (VDU 5), the text cell is 8x8 and the text resolution is 80x43. This mode assumes that the EGA card has 256k of ram. BBCBASIC(86) does not support the 64k EGA card in mode 16. Most 'clone' EGA cards come with 256k of RAM fitted as standard; the IBM EGA card does not.
Mode 18 is available if a VGA is fitted. In this mode the text resolution is 80x30 when the text is written at the text cursor position (VDU 4). If the text is written at the graphics cursor position (VDU 5), the text cell is 8x8 and the text resolution is 80x60.
(The action of VDU 4 and VDU 5 are explained later in this section under the heading of User Defined Characters.)
Modes 8 to 15 have been mapped as closely as possible (as regards graphics resolution and number of text columns) onto CGA modes 0 to 7. This has been done to simplify conversion of software to use the EGA modes. You simply need to add 8 to the original CGA mode number.
You can automatically map the CGA modes 0 to 7 to the EGA modes 8 to 15 with the *EGA command. Normal operation may be restored by issuing the command *EGA OFF.
Graphics operations in the EGA modes are significantly slower than in the CGA modes. Since all EGA cards also support the CGA modes, you should use the CGA modes 0 to 7 unless you actually need EGA features (16 colours, for example).
Attempting to select a screen mode of which the hardware of the computer is not capable should give the 'Bad mode' error, although the screen may first be cleared. However, some computers may 'crash' if no EGA or VGA card is fitted and an attempt is made to select modes 8 to 18 (or modes 0 to 7 after *EGA). This is due to shortcomings of the BIOS fitted to some PC compatibles.
El que puse es un Mode 8 -drinks
Agradecido : 1389 veces
Agradecimiento recibido: 1399 veces
Mensajepor ron » 29 Sep 2017 13:43
Mola !!! ya tienes otra excusa para pasar por la retrocrypta
BBC Rock's ! de hecho tengo una Opus que es exclusiva para BBC Micro, aunque uso el GoMMC de Kortink.
overCLK
Agradecido : 77 veces
Mensajepor overCLK » 29 Sep 2017 13:57
ron escribió:Mola !!! ya tienes otra excusa para pasar por la retrocrypta
Ron macho, esa estantería da miedo verla. -507. Parece que ha habido un naufragio y han acabado ahí los restos. Libros, Opus, datassette, ratones de atari y amiga amenazados por un destornillador. -rofl -rofl
Por cierto, muy chulo el BBC Micro. Felicidades!
Mensajepor Nandove » 10 Oct 2017 19:25
También tengo el hermanito pequeño, mirad el primer post ;)
Mensajepor Nandove » 11 Oct 2017 11:01
Actualizo el primer post con esta info importante:
Mensajepor ron » 11 Oct 2017 12:13
GoMMC has been succeeded by GoSDC.
-drinks -507 -rofl -grin -thumbup
Mensajepor Nandove » 12 Oct 2017 12:41
Me he puesto manos a la obra para actualizar el BBC micro a la dfs1770 y poder leer bien los discos...y me encuentro lo siguiente:
Por lo que me sobra la ampliación q compre hace tiempo para un BBC sin la actualización de la controladora de disco:
Si alguien la quiere q me avise, la dejo a lo mismo q me costo -drinks
Mensajepor ron » 12 Oct 2017 16:25
Hacemos una cosa. Yo tengo el mismo o casi el mismo problema que tu
Pero me interesa mucho, quedamos y lo miramos todo.
Cuenta conmigo.
BBC Session in progress.
Mensajepor Nandove » 26 Mar 2018 21:51
Bueno pues el BBC en una rotación me encontré con que no pitaba y posiblemente desde que lo compré ya que cuando lo probé solo probé vídeo y no audio -shock
Después de mirar foros y demás.... bueno mejor lo explico en vídeo:
https://www.youtube.com/watch?v=oU0wlKkYBTE
