TAP2WAV para Camputers Lynx. Conseguido !!!
Agradecido : 3862 veces
Re: Resolviendo los volcados TAP del Camputers Lynx.
Mensajepor ron » 03 Ene 2014 20:08
Peter Todd escribió:It will just be a question of speed now - I am just looking for a tape lead :)
With your invaluable help we will return the Lynx to life and thus get users who have one, can be used often.
Peter Todd
Mensajepor Peter Todd » 03 Ene 2014 21:31
It works for Tape 3 Basic now on real lynx - I ghave sent you a program DLL update
Peter Todd
Mensajepor Peter Todd » 03 Ene 2014 21:52
Generated from TAP2WAV
AIRRAID1.zip
Generated from PALE TAP2WAV
(10.62 KiB) Descargado 120 veces
Mensajepor ron » 03 Ene 2014 22:53
Does not work neither.
My AIR RAID WAV posted before does work, at least when you issue a LOAD "" the name " AIRRAID" appears. With the latests wav we have generated that thing doesnt happens
Peter Todd
Mensajepor Peter Todd » 03 Ene 2014 23:04
load "" will not work for any Lynx program
yoiu must type
load "AIRRAID1"
Peter Todd
Mensajepor Peter Todd » 03 Ene 2014 23:07
It is not like the Spectrum - the Lynx has to have the name
Peter Todd
Mensajepor Peter Todd » 03 Ene 2014 23:13
This is Mazeman MC program
Loads at Tape 3
MAZEMAN.zip
Mazeman MC loads in Real Lynx at Tape
(15.35 KiB) Descargado 147 veces
Peter Todd
Mensajepor Peter Todd » 03 Ene 2014 23:21
The compression is very good on these WAV files :)
Mensajepor ron » 03 Ene 2014 23:23
Okay Pete.
But when trying to LOAD "", at next line appears the name of the program played from tape / audio. And in my case it does not.
Im trying again....
With my VAW from older version, loads OK
As you can see, you can see the name of the program to be loaded, then load it as usual. WIth your wav theres no way.
Mensajepor ron » 03 Ene 2014 23:32
Peter Todd escribió:This is Mazeman MC program
Loads at Tape 3
Even typing from the basic prompt:
TAPE 3
LOAD " MAZEMAN"
or
MLOAD "MAZEMAN"
I have tryed several volume sets, but my Lynx doesnt recognize any program
Ill test right now with the new DLL, to see if Im able to go forward
Mensajepor ron » 03 Ene 2014 23:39
I just made some wavs with the new DLL and the Lynx doesnt recognize them. Also i have noticed that the speed of the WAV is too fast, isnt it ?
Mensajepor ron » 03 Ene 2014 23:44
OK
NOW SEEMS TO WORK ! GREAT
Just made a new wav ----> TAPE 5
Fantastic !!!
I ll keep trying some more
Mensajepor ron » 03 Ene 2014 23:45
PARTA.rar
(3.72 KiB) Descargado 120 veces
TAPE 5
LOAD "PART A"
AWESOME !!!
Mensajepor ron » 03 Ene 2014 23:50
TAPE 5
MLOAD "MAZEMAN"
YEAH ! Ho ho ho ho !!!
Re: TAP2WAV para Camputers Lynx. Conseguido !!!
Mensajepor ron » 03 Ene 2014 23:59
trek.rar
(16.37 KiB) Descargado 133 veces
Successfully LOADED
Mensajepor ron » 04 Ene 2014 00:05
Dear Pete.
The first thing is to congratulate, you got it
Thank you very much for getting this achievement for all Camputers Lynx users
Im sure it will still move forward on this issue, but its time to enjoy the achievement.
Thanks Pete
Mensajepor ron » 04 Ene 2014 00:09
Como podéis observar, Pete lo ha conseguido. El conversor TAP a WAV ya es operativo.
Mis felicitaciones, ya que este logro es algo muy deseado por todos los que nos gusta el Camputers Lynx.
Hoy es un día grande y una gran forma de comenzar el año. Esto promete-.
Gracias PETE. RW está en deuda contigo !!!
Volver a “Camputers Lynx”
