Odyssey Computing HRG - you see it here first on RW
Peter Todd
Mensajepor Peter Todd » 06 Ene 2014 18:09
I programmed this little demo back in 1982 using a commercial Hires graphics library
I have never seen the Hires Routines used in this commercial tape before.
It took a long time to get it from the author back in the 80s - I think it was a little unfinished.
I have the cassette inlay and will upload later.
The hires uses an intersting method of pseudo commands in string variables
I will scan and uplaod the manual if anyone is interested.
luiscoco
Agradecido : 36 veces
Re: ZX81 Hi Res Routines - RARE Sprites Code
Mensajepor luiscoco » 06 Ene 2014 22:23
slowly, slowly, much to digest, that not enough time
Peter Todd
Mensajepor Peter Todd » 06 Ene 2014 22:36
:) They have been 32 years in the suitcase, the programs are restless! :)
Agradecido : 188 veces
Mensajepor jltursan » 06 Ene 2014 23:57
Hey Peter, you are literally flooding us whith such rare ZX81 gems!. I have always found fascinating the pseudohires tricks a ZX81 must use to get higher resolutions
Agradecido : 1749 veces
Agradecimiento recibido: 1495 veces
Mensajepor ron » 07 Ene 2014 00:08
All the uploads are genuine treasures for ZX81 lovers , is like putting a cake to the school door !!! -507
And the most important thing , are preserved, then can be rediscovered and enjoy again. Thanks for sharing
Peter Todd
Mensajepor Peter Todd » 07 Ene 2014 01:55
Well I hope so, I am so proud of my bros JetPac - and I also retrieved his PacMan which I was in process of converting to HiRes in 1983 when I bought my Lynx.
I can half remember the development sequence for my HiRes PacMan:
Load in My own relocator and Merger
Which relocates ZXAS (which I wrote a reloc in before the ZXAS reloc came out)
Then Load in ASM code
Compile
Delete ZXAS
Merge Hires Routines
Run Program
Thats about a twenty minute development cycle from
edit ASM line
to
crash with pretty pictures looking like snow... but just a little bit annoying... because you know in your heart that you have to spend the next 8 minutes loading all of it back up again.
Looking back its no wonder I didnt finish it. I was only 11. I will dig out the bits and post up a failure - with todays emulators it is so much easier.
Just this evening I was using EightyOne emulator and thought
AAAAAAArrrggggg the keyboard doesnt respond for half a second
Then I reminded myself that it was the typing speed limit on the ZX81! Today it would be an excercise in frustration, back then I thought it was magic.
EDITAR: ok, yeah I STILL think its magic
Nite all.
Peter Todd
Mensajepor Peter Todd » 08 Ene 2014 01:52
I have been tracking down the cassette for this and it turns out to be the
High Resolution Graphics Utility from Odyssey Computing
From the Full text of "Sinclair User Magazine Issue 022" courtesy Inernet Archive:
ODYSSEY COMPUTING, producer of ZX-8 1 high-resolution games and utilities, has been having difficulty with two items in its range. The
tapes in question are High-Resolution Zorf and High- Resolutiun Graphics in which there are several bugs.
The company is doing its best to rectify the situation and will offer money back to customers who have a faulty version of the programs.
It also warns that customers may wait for new tapes or for the fulfilment of orders but it cannot state definitely when the programs will be
ready for re-release.
If customers have queries they should write to Odyssey Computing, 28 Bingham Road, Sherwood, Nottingham, NG5 2EP. Alternatively they can write to the advertising department of Sinclair User.
I think this explains why I had so many problems getting hold of it in the first place.
The tape I have is one of the bugged tapes, and I doubt that it was re-released later as stated.
I will upload the Instruction manual later, it is quite interesting as it includes a Sprite Editor.
Peter Todd
Mensajepor Peter Todd » 08 Ene 2014 02:30
Here is the instruction manual
Odyssey HRG
Odyssey Computing HRG.zip
(75.6 KiB) Descargado 93 veces
Peter Todd
Re: Odyssey Computing HRG - you saw it here first
Mensajepor Peter Todd » 08 Ene 2014 03:11
If you load up the demo file, break out of the program and type GOTO 6000
The screen will restore to normal
Then type GOTO 7000 to get to the HRG menu system
Get into the SPrite EDitor and Choose EDIT SPRITE
Choose Sprite number 1
And after a couple of minutes (!) you will see a sprite that I created in 1984.
Line 8418 needs fixing as there is a bad read off the tape at this point.
Peter Todd
Re: Odyssey Computing HRG - you see it here first on RW
Mensajepor Peter Todd » 08 Ene 2014 03:34
This is a test posting to see if my Wintape program types correctly into the RW forum, it is a segment of the above code:
0 : REM
5 : LET C$=CHR$ 64
6 : RAND USR 16704
7 : LET C$=CHR$ 66+CHR$ 115+CHR$ 0
8 : RAND USR 16704
10 : LET C$=CHR$ 67+ " " +CHR$ 0+CHR$ 127
11 : RAND USR 16704
17 : LET T=5
18 : LET C$=CHR$ 65+CHR$ 5+CHR$ 1+ " #i#am#a#dancing#man...# "
19 : RAND USR 16704
20 : FOR F=0 TO 15 STEP .2
25 : IF T<3 THEN GOTO 36
30 : LET C$=CHR$ 1+CHR$ 90+CHR$ F
31 : RAND USR 16704
Mensajepor jltursan » 08 Ene 2014 20:01
Mmmm, seems that Odyssey Computing did vanish totally from the ZX81 panorama. Theres near to zero software preserved from this house. In fact they suposedly created an Invaders clone using its HRG routine; but it cant be found in the web :evil:
Volver a “Sinclair ZX80/81”
