CESIL Interpreter with Interesting Code Technique
Peter Todd
Mensajepor Peter Todd » 06 Ene 2014 16:45
Back in 1982 I was learning computer education in schools in Wales, UK.
We were taught programming using the language called CESIL which is best described here:
http://www.obelisk.demon.co.uk/cesil/
I was 11 years old at the time and thought that I would have a go at writing an interpreter
for the CESIL language on my ZX81.
The result is the attached.
I am downloading the file from a backup tape and I will post it here.
I still think this is one of my cleverest programs.
Usually you would have to write your own arithmetic routines, and the ZX81 has no EVAL function on string variables.
So my solution is shown here, see if you can work it out before I upload the P file.
Best Regards to all (Im moonlighting from the Camputers Lynx group)
CESILCPDT1982.zip
CESIL Interpreter Peter Todd 1982
(14.36 KiB) Descargado 58 veces
Peter
Peter Todd
Re: CESIL Interpreter with Interesting Code Technique
Mensajepor Peter Todd » 06 Ene 2014 17:01
Do not be confused by the machine code in line 0
it is a HALF FAST routine for speeding up the zx81 that I typed in from a magazine.
Peter Todd
Mensajepor Peter Todd » 06 Ene 2014 18:14
Here is the P file
cesil.zip
CESIL Interpreter CPDT 1982
(2.15 KiB) Descargado 55 veces
Agradecido : 1750 veces
Agradecimiento recibido: 1497 veces
Mensajepor ron » 06 Ene 2014 21:49
Gracias Pete, eres de lo mejor que le ha pasado recientemente a RW.
Peter Todd
Mensajepor Peter Todd » 07 Ene 2014 12:24
I cannot work out how to break into this program
change line 1125 to LET V = 0
and then save it.
I have tried this in VB81 and it doesnt seem to save a file anywhere
I tried it in EightyOne but I cannot break into the program.
Any ideas?
Agradecido : 193 veces
Mensajepor dancresp » 07 Ene 2014 15:21
ron escribió:Gracias Pete, eres de lo mejor que le ha pasado recientemente a RW.
Totalmente de acuerdo.
Esto le va a dar más vidilla a nuestros ZX-81.
Por cierto, me he descargado el CECIL y en el tren de vuelta a casa lo probaré.
-drinks
Volver a “Sinclair ZX80/81”
