Emulador de ZX81 para Spectrum
Agradecido : 1746 veces
Agradecimiento recibido: 1493 veces
Mensajepor ron » 19 Sep 2012 23:43
Acabo de leer el hilo que acaba de publicar antoniovillena: Emulador de Spectrum para Jupiter Ace y casi se me pasa.
Algunos ya lo conoceréis:
La web en donde está alojado usualmente es: http://www.zx81.nl/
Hello ZX81 fans!
Here's a wonderful ZX81 emulator who runs in the ZX-Spectrum! Simply
load the snapshot ZX81.Z80 into your ZX-Spectrum emulator and you're
working with a simulated-simulated ZX81!!!
There's the game "3D MONSTER MAZE" in the ZX81, to break it,
press Shift+Space (the same as the BREAK for ZX-Spectrum) and then
enter the NEW command (identical to the Speccy).
The emulated ZX81 resets and after a short while the ZX81 prompt waits
for your input. Great, isn't it?
The keyboard layout corresponds to the real ZX81, here some special
notes:
To reach special BASIC tokens, you have to enable the (F)unction mode
by pressing left Caps-Shift+ENTER on your ZX-Spectrum.
The Point key "." is the right Caps-Shift key on your simulated ZX-
Spectrum keyboard, so to get the comma, hold down the left shift
and press the right shift once.
I found that the ZX81 emulator works best with about 250 % Speccy
speed.
Loading converted *.P files:
I got some converted .P files as .TAP files. To load these games,
simply set the desired game as TAPE INPUT file and enter LOAD"" on
your simulated ZX81.
Converting *.P files into Spectrum *.TAP files:
Use the small converting tool XTEN2TAP.EXE to convert any .P file
into .TAP
An example:
XTEN2TAP ASTEROID.P ASTEROID.TAP
Claus Jahn.
P.S.: Thanks for Ronald Raaijen who gave me all that nice files.
zx81-speccy.zip
Yo lo he probado en un par de emus y funciona. ¿ Alguien lo puede probar en un Speccy real ?
Agradecido : 309 veces
Re: Emulador de ZX81 para Spectrum
Mensajepor Luis » 20 Sep 2012 04:31
Uff yo esto lo probé hace unos años en mi gomas, y duró cosa de 5 minutos en la memoria, los que me tiré para escribir algo como 10 PRINT "HOLA". Increíblemente lento.
Sinceramente, no veo la gracia por ningún sitio de hacer algo así, si no puede funcionar en la máquina real.
javu61
Mensajepor javu61 » 20 Sep 2012 08:58
Hay otra opción, cambiar la ROM del Spectrum por una que lo convierte en un ZX80, un ZX81 o un Jupiter, para lo que lo mas sencillo es montarla en un cartucho, así no hay ni que abrir el aparato para cambiarla. Los teneis aquí
Volver a “Sinclair ZX80/81”
