GSPort: Emulador de Apple IIGS: ¿Compilarlo para Linux x86_64?
timofonic
Mensajepor timofonic » 28 Ene 2017 13:06
Buenas.
No encuentro otros emuladores recientes de Apple IIGS, salgo GSPort.
http://gsport.sourceforge.net
https://github.com/robinhood2014/GSport
Lo quiero compilar para mi Linux y aquí hay instrucciones para compilarlo, el problema es que falta un fichero para x86_64:
Use the vars_x86linux file:
cd into the src/ directory
rm vars; ln -s vars_x86linux vars
make
The resulting executable is called gsportx.
The build scripts assume perl is in your path. If it is somewhere else, you need to edit the "PERL = perl" line in the vars file and make it point to the correct place.
For audio, GSport needs access to /dev/dsp. If the permissions do not allow GSport to access /dev/dsp, it can fail with a cryptic error message. As root, just do: chmod 666 /dev/dsp .
If you do not have the /dev/dsp device, GSport will not start unless you tell it to disable audio with the following command-line argument: ./gsportx -audio 0
El problema está en que ese fichero no me vale, ya que esto es x86_64:
TARGET = gsportx
OBJECTS = $(OBJECTS1) $(TFEOBJ) $(ATOBJ) $(PCAPOBJ) xdriver.o
CC = gcc
CCOPTS = -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=i686 -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS
OPTS = -DGSPORT_LITTLE_ENDIAN
SUFFIX =
NAME = gsportx
LDFLAGS =
LDOPTS =
LD = g++
EXTRA_LIBS = -lXext
EXTRA_SPECIALS =
AS = cc
PERL = perl
XOPTS = -I/usr/X11R6/include
¿Qué modificar? A ver si cambiando por -march=native y renombrando, vale...
# cat vars_x86_64linux
ARGET = gsportx
CC = gcc
CCOPTS = -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS
SUFFIX =
NAME = gsportx
LDFLAGS =
LDOPTS =
LD = g++
EXTRA_LIBS = -lXext
EXTRA_SPECIALS =
AS = cc
PERL = perl
# rm vars; ln -s vars_x86_64linux vars
Pero hay fallos...
¿Alguna idea?
# make
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o adb.o adb.c
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o clock.o clock.c
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o config.o config.c
config.c: In function ‘cfg_stat’:
config.c:1924:6: warning: variable ‘len’ set but not used [-Wunused-but-set-variable]
int len;
config.c:1923:6: warning: variable ‘removed_slash’ set but not used [-Wunused-but-set-variable]
int removed_slash;
config.c: In function ‘config_control_panel’:
config.c:3176:9: warning: variable ‘j’ set but not used [-Wunused-but-set-variable]
int i, j;
config.c: In function ‘config_parse_config_gsport_file’:
config.c:1060:5: warning: assuming signed overflow does not occur when assuming that (X + c) >= X is always true [-Wstrict-overflow]
if((pos + 4) > len || buf[pos] != s || buf[pos+2] != d ||
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o dis.o dis.c
dis.c: In function ‘do_step’:
dis.c:613:6: warning: variable ‘size’ set but not used [-Wunused-but-set-variable]
int size;
dis.c: In function ‘do_debug_unix’:
dis.c:812:12: warning: variable ‘save’ set but not used [-Wunused-but-set-variable]
int load, save;
perl make_inst c 8 instable.h > 8inst_c.h
perl make_inst c 16 instable.h > 16inst_c.h
perl make_size c size_tab.h > size_c.h
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o engine_c.o engine_c.c
engine_c.c: In function ‘get_memory16_pieces_stub’:
engine_c.c:415:9: warning: variable ‘addr_latch’ set but not used [-Wunused-but-set-variable]
word32 addr_latch;
engine_c.c: In function ‘get_memory24_pieces_stub’:
engine_c.c:441:9: warning: variable ‘addr_latch’ set but not used [-Wunused-but-set-variable]
word32 addr_latch;
engine_c.c: In function ‘get_memory_c’:
engine_c.c:569:9: warning: variable ‘addr_latch’ set but not used [-Wunused-but-set-variable]
word32 addr_latch;
engine_c.c: In function ‘fixed_memory_ptrs_shut’:
engine_c.c:780:18: warning: operation on ‘g_rom_cards_ptr’ may be undefined [-Wsequence-point]
g_rom_cards_ptr = g_rom_cards_ptr = NULL;
engine_c.c: In function ‘get_remaining_operands’:
engine_c.c:844:9: warning: variable ‘addr_latch’ set but not used [-Wunused-but-set-variable]
word32 addr_latch;
engine_c.c: In function ‘enter_engine’:
engine_c.c:937:10: warning: variable ‘tmp_pc_ptr’ set but not used [-Wunused-but-set-variable]
Pc_log *tmp_pc_ptr;
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o scc.o scc.c
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o iwm.o iwm.c
iwm.c: In function ‘iwm_touch_switches’:
iwm.c:417:8: warning: variable ‘dsk’ set but not used [-Wunused-but-set-variable]
Disk *dsk;
In file included from iwm.c:1060:0:
iwm_35_525.h: In function ‘iwm_read_data_35’:
iwm_35_525.h:110:4: warning: assuming signed overflow does not occur when assuming that (X + c) < X is always false [-Wstrict-overflow]
if(cycs_passed >= (cycs_this_nib + 11)) {
In file included from iwm.c:1071:0:
iwm_35_525.h: In function ‘iwm_read_data_525’:
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o joystick_driver.o joystick_driver.c
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o moremem.o moremem.c
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o paddles.o paddles.c
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o parallel.o parallel.c
gcc -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. printer.cpp
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o sim65816.o sim65816.c
sim65816.c:157:19: warning: ‘g_gsport_version_str’ initialized and declared ‘extern’
extern const char g_gsport_version_str[] = "0.31";
sim65816.c: In function ‘show_pc_log’:
sim65816.c:316:6: warning: variable ‘num’ set but not used [-Wunused-but-set-variable]
int num;
sim65816.c: In function ‘my_exit’:
sim65816.c:739:2: warning: implicit declaration of function ‘imagewriter_close’ [-Wimplicit-function-declaration]
imagewriter_close();
sim65816.c: In function ‘do_reset’:
sim65816.c:752:13: warning: unused variable ‘g_scan_int_events’ [-Wunused-variable]
extern int g_scan_int_events ;
sim65816.c: In function ‘run_prog’:
sim65816.c:1651:6: warning: variable ‘this_type’ set but not used [-Wunused-but-set-variable]
int this_type;
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o smartport.o smartport.c
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o sound.o sound.c
sound.c: In function ‘sound_play’:
sound.c:728:6: warning: variable ‘num_running’ set but not used [-Wunused-but-set-variable]
int num_running;
sound.c: In function ‘doc_write_ctl_reg’:
sound.c:1521:6: warning: variable ‘mode’ set but not used [-Wunused-but-set-variable]
int mode;
sound.c: In function ‘doc_read_c03d’:
sound.c:1687:9: warning: variable ‘dsamps’ set but not used [-Wunused-but-set-variable]
double dsamps;
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o sound_driver.o sound_driver.c
sound_driver.c: In function ‘child_sound_init_linux’:
sound_driver.c:372:6: warning: variable ‘fragment’ set but not used [-Wunused-but-set-variable]
int fragment;
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o video.o video.c
In file included from video.c:24:0:
defc.h:63:10: warning: result of ‘252641280 << 8’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
(((a) << 8) & 0xff0000) +
video.c:217:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0000),
defc.h:64:10: warning: result of ‘252641280 << 24’ requires 53 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
(((a) << 24) & 0xff000000))
BIGEND(0x0f0f0000),
defc.h:64:10: warning: result of ‘3855 << 24’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:218:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x00000f0f),
defc.h:63:10: warning: result of ‘252645135 << 8’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:219:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0f0f)
defc.h:64:10: warning: result of ‘252645135 << 24’ requires 53 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
BIGEND(0x0f0f0f0f)
defc.h:63:10: warning: result of ‘251658240 << 8’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:224:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f000000),
defc.h:64:10: warning: result of ‘251658240 << 24’ requires 53 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
BIGEND(0x0f000000),
defc.h:64:10: warning: result of ‘983040 << 24’ requires 45 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:225:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x000f0000),
video.c:226:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0000),
BIGEND(0x0f0f0000),
defc.h:64:10: warning: result of ‘3840 << 24’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:228:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x00000f00),
defc.h:63:10: warning: result of ‘251662080 << 8’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:229:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f000f00),
defc.h:64:10: warning: result of ‘251662080 << 24’ requires 53 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
BIGEND(0x0f000f00),
defc.h:64:10: warning: result of ‘986880 << 24’ requires 45 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:230:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x000f0f00),
defc.h:63:10: warning: result of ‘252645120 << 8’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:231:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0f00),
defc.h:64:10: warning: result of ‘252645120 << 24’ requires 53 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
BIGEND(0x0f0f0f00),
defc.h:63:10: warning: result of ‘251658255 << 8’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:234:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f00000f),
defc.h:64:10: warning: result of ‘251658255 << 24’ requires 53 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
BIGEND(0x0f00000f),
defc.h:64:10: warning: result of ‘983055 << 24’ requires 45 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:235:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x000f000f),
defc.h:63:10: warning: result of ‘252641295 << 8’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:236:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f000f),
defc.h:64:10: warning: result of ‘252641295 << 24’ requires 53 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
BIGEND(0x0f0f000f),
video.c:238:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x00000f0f),
defc.h:63:10: warning: result of ‘251662095 << 8’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:239:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f000f0f),
defc.h:64:10: warning: result of ‘251662095 << 24’ requires 53 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
BIGEND(0x0f000f0f),
defc.h:64:10: warning: result of ‘986895 << 24’ requires 45 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:240:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x000f0f0f),
video.c:241:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0f0f),
BIGEND(0x0f0f0f0f),
defc.h:63:10: warning: result of ‘50528256 << 8’ requires 35 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:247:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x03030000), /* 00,0010 = purp , purp , black, black */
defc.h:64:10: warning: result of ‘50528256 << 24’ requires 51 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:248:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0000), /* 00,0011 = white, white, black, black */
defc.h:64:10: warning: result of ‘3084 << 24’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:249:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x00000c0c), /* 00,0100 = black, black, green, green */
defc.h:63:10: warning: result of ‘202116108 << 8’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:250:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0c0c0c0c), /* 00,0101 = green, green, green, green */
defc.h:64:10: warning: result of ‘202116108 << 24’ requires 53 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:251:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0f0f), /* 00,0110 = white, white, white, white */
video.c:252:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0f0f), /* 00,0111 = white, white, white, white */
defc.h:63:10: warning: result of ‘50529027 << 8’ requires 35 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:255:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x03030303), /* 00,1010 = purp , purp , purp , purp */
defc.h:64:10: warning: result of ‘50529027 << 24’ requires 51 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
defc.h:63:10: warning: result of ‘252642051 << 8’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:256:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0303), /* 00,1011 = white ,white, purp , purp */
defc.h:64:10: warning: result of ‘252642051 << 24’ requires 53 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:257:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x00000f0f), /* 00,1100 = black ,black, white, white */
defc.h:63:10: warning: result of ‘202116879 << 8’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:258:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0c0c0f0f), /* 00,1101 = green ,green, white, white */
defc.h:64:10: warning: result of ‘202116879 << 24’ requires 53 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:259:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0f0f), /* 00,1110 = white ,white, white, white */
video.c:260:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0f0f), /* 00,1111 = white ,white, white, white */
defc.h:63:10: warning: result of ‘101056512 << 8’ requires 36 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:264:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x06060000), /* 01,0010 = blue , blue , black, black */
defc.h:64:10: warning: result of ‘101056512 << 24’ requires 52 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:265:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0000), /* 01,0011 = white, white, black, black */
video.c:266:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x00000c0c), /* 01,0100 = black, black, green, green */
defc.h:63:10: warning: result of ‘151587852 << 8’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:267:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x09090c0c), /* 01,0101 = orang, orang, green, green */
defc.h:64:10: warning: result of ‘151587852 << 24’ requires 53 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:268:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0f0f), /* 01,0110 = white, white, white, white */
video.c:269:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0f0f), /* 01,0111 = white, white, white, white */
defc.h:63:10: warning: result of ‘101057283 << 8’ requires 36 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:272:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x06060303), /* 01,1010 = blue , blue , purp , purp */
defc.h:64:10: warning: result of ‘101057283 << 24’ requires 52 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:273:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0303), /* 01,1011 = white ,white, purp , purp */
video.c:274:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x00000f0f), /* 01,1100 = black ,black, white, white */
defc.h:63:10: warning: result of ‘151588623 << 8’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:275:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x09090f0f), /* 01,1101 = orang ,orang, white, white */
defc.h:64:10: warning: result of ‘151588623 << 24’ requires 53 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:276:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0f0f), /* 01,1110 = white ,white, white, white */
video.c:277:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0f0f), /* 01,1111 = white ,white, white, white */
video.c:281:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x03030000), /* 10,0010 = purp , purp , black, black */
video.c:282:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0000), /* 10,0011 = white, white, black, black */
defc.h:64:10: warning: result of ‘2313 << 24’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:283:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x00000909), /* 10,0100 = black, black, orang, orang */
defc.h:63:10: warning: result of ‘202115337 << 8’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:284:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0c0c0909), /* 10,0101 = green, green, orang, orang */
defc.h:64:10: warning: result of ‘202115337 << 24’ requires 53 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:285:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0f0f), /* 10,0110 = white, white, white, white */
video.c:286:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0f0f), /* 10,0111 = white, white, white, white */
defc.h:63:10: warning: result of ‘50529798 << 8’ requires 35 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:289:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x03030606), /* 10,1010 = purp , purp , blue , blue */
defc.h:64:10: warning: result of ‘50529798 << 24’ requires 51 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
defc.h:63:10: warning: result of ‘252642822 << 8’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:290:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0606), /* 10,1011 = white ,white, blue , blue */
defc.h:64:10: warning: result of ‘252642822 << 24’ requires 53 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:291:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x00000f0f), /* 10,1100 = black ,black, white, white */
video.c:292:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0c0c0f0f), /* 10,1101 = green ,green, white, white */
video.c:293:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0f0f), /* 10,1110 = white ,white, white, white */
video.c:294:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0f0f), /* 10,1111 = white ,white, white, white */
video.c:298:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x06060000), /* 11,0010 = blue , blue , black, black */
video.c:299:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0000), /* 11,0011 = white, white, black, black */
video.c:300:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x00000909), /* 11,0100 = black, black, orang, orang */
defc.h:63:10: warning: result of ‘151587081 << 8’ requires 37 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:301:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x09090909), /* 11,0101 = orang, orang, orang, orang */
defc.h:64:10: warning: result of ‘151587081 << 24’ requires 53 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:302:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0f0f), /* 11,0110 = white, white, white, white */
video.c:303:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0f0f), /* 11,0111 = white, white, white, white */
defc.h:63:10: warning: result of ‘101058054 << 8’ requires 36 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:306:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x06060606), /* 11,1010 = blue , blue , blue , blue */
defc.h:64:10: warning: result of ‘101058054 << 24’ requires 52 bits to represent, but ‘int’ only has 32 bits [-Wshift-overflow=]
video.c:307:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0606), /* 11,1011 = white ,white, blue , blue */
video.c:308:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x00000f0f), /* 11,1100 = black ,black, white, white */
video.c:309:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x09090f0f), /* 11,1101 = orang ,orang, white, white */
video.c:310:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0f0f), /* 11,1110 = white ,white, white, white */
video.c:311:2: note: in expansion of macro ‘BIGEND’
BIGEND(0x0f0f0f0f), /* 11,1111 = white ,white, white, white */
video.c: In function ‘video_init’:
video.c:328:9: warning: variable ‘match_col’ set but not used [-Wunused-but-set-variable]
word32 match_col;
video.c: In function ‘redraw_changed_text_40’:
video.c:1198:6: warning: variable ‘ch_bitpos’ set but not used [-Wunused-but-set-variable]
int ch_bitpos;
video.c: In function ‘redraw_changed_text_80’:
video.c:1375:6: warning: variable ‘ch_bitpos’ set but not used [-Wunused-but-set-variable]
int ch_bitpos;
video.c: In function ‘redraw_changed_gr’:
video.c:1563:6: warning: variable ‘ch_bitpos’ set but not used [-Wunused-but-set-variable]
int ch_bitpos;
video.c: In function ‘redraw_changed_dbl_gr’:
video.c:1689:6: warning: variable ‘ch_bitpos’ set but not used [-Wunused-but-set-variable]
int ch_bitpos;
video.c: In function ‘redraw_changed_hires_bw’:
video.c:1841:6: warning: variable ‘ch_bitpos’ set but not used [-Wunused-but-set-variable]
int ch_bitpos;
video.c: In function ‘redraw_changed_hires_color’:
video.c:1964:6: warning: variable ‘ch_bitpos’ set but not used [-Wunused-but-set-variable]
int ch_bitpos;
video.c: In function ‘redraw_changed_dbl_hires_bw’:
video.c:2111:6: warning: variable ‘ch_bitpos’ set but not used [-Wunused-but-set-variable]
int ch_bitpos;
video.c: In function ‘redraw_changed_dbl_hires_color’:
video.c:2232:6: warning: variable ‘ch_bitpos’ set but not used [-Wunused-but-set-variable]
int ch_bitpos;
video.c: In function ‘video_rebuild_super_hires_palette’:
video.c:2355:6: warning: variable ‘palette_changed’ set but not used [-Wunused-but-set-variable]
int palette_changed;
In file included from video.c:2479:0:
superhires.h: In function ‘redraw_changed_super_hires_oneline_nofill_8’:
superhires.h:34:14: warning: variable ‘tmp2’ set but not used [-Wunused-but-set-variable]
word32 tmp, tmp2;
In file included from video.c:2495:0:
superhires.h: In function ‘redraw_changed_super_hires_oneline_nofill_32’:
word32 tmp, tmp2;
superhires.h:34:9: warning: variable ‘tmp’ set but not used [-Wunused-but-set-variable]
word32 tmp, tmp2;
In file included from video.c:2503:0:
superhires.h: In function ‘redraw_changed_super_hires_oneline_fill_8’:
word32 tmp, tmp2;
In file included from video.c:2519:0:
superhires.h: In function ‘redraw_changed_super_hires_oneline_fill_32’:
word32 tmp, tmp2;
word32 tmp, tmp2;
video.c: In function ‘redraw_changed_super_hires’:
video.c:2539:9: warning: variable ‘kd_tmp_debug’ set but not used [-Wunused-but-set-variable]
word32 kd_tmp_debug;
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o scc_socket_driver.o scc_socket_driver.c
gcc -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. imagewriter.cpp
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o scc_imagewriter.o scc_imagewriter.c
scc_imagewriter.c: In function ‘scc_imagewriter_init’:
scc_imagewriter.c:43:2: warning: implicit declaration of function ‘imagewriter_init’ [-Wimplicit-function-declaration]
imagewriter_init(g_imagewriter_dpi,85,110,g_imagewriter_output,g_imagewriter_multipage != 0, port);
scc_imagewriter.c: In function ‘scc_imagewriter_empty_writebuf’:
scc_imagewriter.c:125:3: warning: implicit declaration of function ‘imagewriter_loop’ [-Wimplicit-function-declaration]
imagewriter_loop(scc_ptr->out_buf[rdptr],port);
scc_imagewriter.c: In function ‘imagewriter_update’:
scc_imagewriter.c:153:3: warning: implicit declaration of function ‘imagewriter_feed’ [-Wimplicit-function-declaration]
imagewriter_feed();
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o scc_llap.o scc_llap.c
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o tfe/tfe.o tfe/tfe.c
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o tfe/tfearch.o tfe/tfearch.c
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o tfe/tfesupp.o tfe/tfesupp.c
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o atbridge/aarp.o atbridge/aarp.c
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o atbridge/atbridge.o atbridge/atbridge.c
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o atbridge/elap.o atbridge/elap.c
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o atbridge/llap.o atbridge/llap.c
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o atbridge/port.o atbridge/port.c
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o atbridge/pcap_delay.o atbridge/pcap_delay.c
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o xdriver.o xdriver.c
gcc -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS -I/usr/X11R6/include -c -DGSPORT_LITTLE_ENDIAN -I. -o compile_time.o compile_time.c
g++ -O2 -Wall -fomit-frame-pointer -std=gnu99 -march=native -DHAVE_TFE -DHAVE_ATBRIDGE -DTOGGLE_STATUS adb.o clock.o config.o dis.o engine_c.o scc.o iwm.o joystick_driver.o moremem.o paddles.o parallel.o printer.o sim65816.o smartport.o sound.o sound_driver.o video.o scc_socket_driver.o imagewriter.o scc_imagewriter.o scc_llap.o tfe/tfe.o tfe/tfearch.o tfe/tfesupp.o atbridge/aarp.o atbridge/atbridge.o atbridge/elap.o atbridge/llap.o atbridge/port.o atbridge/pcap_delay.o xdriver.o compile_time.o -o gsportx -L/usr/X11R6/lib -lXext -lX11
/usr/bin/ld: atbridge/pcap_delay.o: undefined reference to symbol dlclose@@GLIBC_2.2.5
/usr/lib/libdl.so.2: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
make: *** [Makefile:65: gsportx] Error 1
Agradecido : 6762 veces
Agradecimiento recibido: 2602 veces
Re: GSPort: Emulador de Apple IIGS: ¿Compilarlo para Linux x86_64?
Mensajepor minter » 29 Ene 2017 01:23
cpcbegin
Agradecido : 295 veces
Agradecimiento recibido: 196 veces
Mensajepor cpcbegin » 29 Ene 2017 09:39
Yo he conseguido compilar e instalar linapple sin mucho problema en Ubuntu 16.04 de 64 bits, no se si te servirá.
timofonic
Mensajepor timofonic » 29 Ene 2017 15:12
cpcbegin escribió:Yo he conseguido compilar e instalar linapple sin mucho problema en Ubuntu 16.04 de 64 bits, no se si te servirá.
Linapple es un emulador de Apple II. Apple IIGS es una super evolución 16bts retrocompatible del Apple II, por mucho que el nombre lleve a engaños y exista el Apple III.
timofonic
Mensajepor timofonic » 29 Ene 2017 15:24
También encontré esto:
http://askubuntu.com/questions/334884/w ... closeglibc
http://stackoverflow.com/questions/1990 ... mmand-line
http://askubuntu.com/questions/527665/u ... libc-2-2-5
https://bbs.archlinux.org/viewtopic.php?id=193412
¿Qué hago con el fichero vars?
Perdón, pero no tengo ni idea de programación y estoy muy confuso. He probado varios intentos y nada.
TARGET = gsportx
CC = gcc
SUFFIX =
NAME = gsportx
LDFLAGS =
LDOPTS =
LD = g++
EXTRA_LIBS = -lXext
EXTRA_SPECIALS =
engo ni
AS = cc
PERL = perl
Estoy en Archlinux. Me quejaba de Gentoo y su dificultad, pero encuentro cosas como esta y GSPort no tiene AUR (son como los paquetes por fuentes de Archlinux).
He preguntado aquí a ver si alguien se anima a sacar un PKGBUILD, a ver si hay suerte.
timofonic
Mensajepor timofonic » 29 Ene 2017 16:00
Me ha costado, pero he encontrado el sucesor de GSPort y KEGS: GSPlus.
Compila a la primera, menos mal...
