[ST] Emulando Atari ST con un 486.
Agradecido : 1188 veces
Mensajepor ron » 30 Oct 2010 23:21
Mediante el emulador PaCifiST y un 486 a partir de 33 Mhz puedes emular un Atari ST
CONFIGURACIÓN DEL SOFTWARE
Descarga el software aquí. Descomprimelo en la raiz del disco C. PaCifiST v0.48 INI file
http://www.retrogames.cl/imagenes/proye ... istoco.rar
[video]
refreshrate = 1
monochrome = no   coloca yes si quieres monitor monocromo alta definicion
fastvideo=yes
render = screen   SCREEN MODE at startup
vbemode= 0   set it to ? in order to create VBEMODES.LST
[system]
ste=no   Partial STE shifter emulation?
pcdrive = no   REALLY NOT RECOMMENDED. sorry to insist..
kbdelay = 2   delay between two bytes in IKBD packets
sensitivity = 4   Mouse sensitivity (not with build-driver)
Internalmouse = no
mousecom=1
joystick=yes
laptop=no   RIGHT CTRL key used as joystick fire button
serial=no
autorun=no
ramsize=1   you can specify 512k for an half meg ST
Sound=yes
volume=255
samples=yes
midi=no   YES for MIDI OUT emulation, but then no sound!
image=disk.st
image=disk.st
mount=c:ststfiles  puedes colocar cuantos mount quieras a cualquier carpeta o unidad
; multiple TOS can now be specified, last listed one ; being default. You can change from one to another ; with the command under monitor. ; tosbase is no more required. ; the second argument (optional) may describe each TOS. ;----------------------------------------------------------------------------
tos = c:st   osTos205es.ROM,"TOS 1.00 (fr)"     aqui va el directorio del tos
[debug]
logfile=st.log
trapirq = none
logirq = none
cualquier duda hay que revisar el leame “pacifist.doc” en la carpeta docs
configuracion autoexec.bat
@ECHO OFF
PROMPT $p$g
PATH C:DOS;
SET TEMP=C:DOS
LMOUSE
@ECHO OFF
IF "%config%"=="ST" GOTO ST
IF "%config%"=="MAC" GOTO MAC
:ST
MSCDEX.EXE /D:mscd001 /L:D
C:
cd system
cd st
pacifist.exe
GOTO QUIT
cd system
cd mac
fusion.exe
echo.
GOTO QUIT
:HELP
CLS
GOTO QUIT
:QUIT
configuracion config.sys
[menu]
menuitem=ST, ATARI ST.
menuitem=MAC, MAC OS.
menuitem=DOS,DOS.
menudefault=ST,30
menucolor=7,0
[ST]
device=himem.sys
device=oakcdrom.sys /D:mscd001
device=btcdrom.sys /D:mscd001
device=aspicd.sys /D:mscd001
[MAC]
device=himem.sys
ren device=btcdrom.sys /D:mscd001
ren device=aspicd.sys /D:mscd001
[DOS]
device=himem.sys
Fuente : http://www.retrogames.cl/emulast.html
