ZEsarUX 6.1 BETA
chernandezba
ZEsarUX 6.1 BETA
Mensajepor chernandezba » 26 Ene 2018 18:48
Hola
He subido una nueva versión BETA de ZEsarUX 6.1. Puedes descargarlo de la url beta habitual:
https://sourceforge.net/projects/zesaru ... _versions/
Hay versiones compiladas de Mac y Windows. Los usuarios de Linux debéis compilar de código fuente:
https://sourceforge.net/p/zesarux/code/ci/master/tree/
La lista de cambios para esta versión es:
Version 6.1. 26 January 2018 - Xeno edition
Added BetaDisk and TR-DOS emulation
Added Spectrum +3 emulation
Added Spectrum keyboard ghosting error feature
Added ZX Spectrum Recreated keyboard support
Added setting to exit emulator after a number of seconds (--exit-after)
Added setting to show changelog when updating emulator version
Added actions to file utilities: Copy, Move, Rename
Added setting to write protect IDE, MMC, ZX-Uno Flash
Added setting to disable persistent writes IDE, MMC
Added two more GUI styles: Clean and CleanInverse
Added second Easter Egg ;)
Improved joystick support:
* added joystick test menu
* buttons to events and buttons to joystick configuration are saved on configuration file
Improved OSD keyboard:
* now you can press up to all 40 keys (on Spectrum/ZX80/ZX81) at the same time
* now it can be opened from any place (needs multitask on)
Improved QL emulation:
* experimental support of LOAD, LRUN command
* can now open qlay mdv microdrive image files
Improved file viewer from file utilities:
*specific file viewers for these kind of files: .tap, .zx, .zsf, .sp, .z80, .sna, .spg, .p, .o, .mmc/.ide (fat browser, plus3dos browser), .dsk, .trd, .tzx, .cdt, .flash (zxuno flash, z88 flash, superupgrade flash), .epr, .eprom
*default hexadecimal file viewer for unknown files
Improved messages windows. You can now have an internal clipboard, press key c to copy to it. Press P on file utils to paste contents to a file
Improved menus, a new "tabbed" menus to improve usability and interaction with mouse, joystick and stdout driver: waveform, visualmem, ay player
Improved menu: now character width can be reduced to 7,6 or 5 pixels width
Improved sound: Silence detector does not activate on pthreads versions
Improved default configuration: when the configuration file doesn't exist, the new one has the autosave configuration setting enabled
Fixed TBBlue MMU when using segment 0000-3FFFH
Fixed ZX-Uno emulation: 128kb timings are the same as a Spectrum 128k. When port 1ffd enabled, port FF return FF
Fixed window footer when running Pentagon
ZEsarUX
