ZEsarUX beta 8 Septiembre 2017
chernandezba
Mensajepor chernandezba » 08 Sep 2017 19:46
Hola
He subido una nueva version BETA de ZEsarUX en la url habitual:
https://sourceforge.net/projects/zesaru ... _versions/
Versiones Linux, Mac y Windows
Por cierto, para los usuarios de ZX-Uno, agradecería que probaséis la emulación de dicha máquina. He hecho cambios internos del gestor de memoria y me gustaria estar seguro de que funcione correctamente. Gracias!
Cambios desde la anterior beta: (lo siento, para ir rápido, en inglés. Si alguien tiene dudas que me pregunte)
Added menu to view color palettes
Added feature "memory zone" to ZRCP and all menus that inspect memory (debug, disassemble, sprites etc): now you can look at all memory zones, for example: full 128kb ram, 64kb rom of +2A, divmmc ram, etc
Added boot logo
Improved menu interface:
*colours are greyscaled when multitask disabled
*allow blinking text, like the input cursor (needs multitask on)
*new splash window type which disappears automatically (needs multitask on). Used only on change memory zones from debug cpu menu, but it will be used on more places probably
Improved debugger:
*you can now set conditions for all flags, written as: FS,FZ,FP,FV,FH,FN,FC
*now breakpoints are evaluated before running the current opcode (instead of after). So breakpoints like "PC=0" and doing a reset from menu, now works
*now you can set breakpoints from command line/config file but not enabled by default. You need --enable-breakpoints setting
*now the multitask setting is not lost when a breakpoint is fired
Improved Sprite Viewer: set bpp (8,4,2,1), set palette
Improved messages windows. Can now find text using f and n
Improved footer. Host CPU % usage on footer is not enabled by default to avoid confussion with emulated CPU speed. You can enable it with a setting. Host CPU % usage is not show on Windows.
Improved ZX-Uno MMU. Only internal functions rewritten, but no different emulation functionality
And some other changes I don't remember ;)
Para ver la lista completa de cambios de la 5.1:
https://sourceforge.net/p/zesarux/code/ ... /Changelog
Recordad de nuevo que es una versión BETA y muchas cosas pueden fallar
Cesar
ZEsarUX
Agradecido : 856 veces
Agradecimiento recibido: 910 veces
Re: ZEsarUX beta 8 Septiembre 2017
Mensajepor ron » 08 Sep 2017 19:49
Hace media hora que lo he descargado y compilado y de hecho iba a hacer ahora una retrocrypta con el zesarux !
Reviso esto, la verdad que va de LUJO, es un gustazo.
chernandezba
Mensajepor chernandezba » 08 Sep 2017 19:51
Gracias! :)
ZEsarUX
chernandezba
Mensajepor chernandezba » 08 Sep 2017 19:52
ron escribió:Hace media hora que lo he descargado y compilado y de hecho iba a hacer ahora una retrocrypta con el zesarux !
Vas a hacer una emisión en directo?
ZEsarUX
Mensajepor ron » 08 Sep 2017 20:02
si señor, estaba intentando terminar una mini recopilación y a ver si el realizador se viene a dar cera a dos cosas importantes.
Cuando vea que todo ta ok le doy cera, de aquí a un rato
chao
chernandezba
Mensajepor chernandezba » 08 Sep 2017 20:04
ok, bueno pasa el link (eso es en youtube?) y si puedo lo veo ;)
Gracias!
ZEsarUX
Mensajepor ron » 08 Sep 2017 20:35
bueno , si tuvieras skype o gtalk o algo para comunicarnos, ya la bomba !!!
Pásamelo por privado, o alguna forma de contactar, creo que hay algunas cosas del zesarux que nos podías contar.
Espero a ver que me dices.
chernandezba
Mensajepor chernandezba » 08 Sep 2017 22:15
Mi id de skype es el mismo que mi mail, chernandezba
Si me agregas me conecto un momentillo
ZEsarUX
Agradecido : 1164 veces
Agradecimiento recibido: 491 veces
Mensajepor minter » 08 Sep 2017 22:19
cagoenmimantu... y ahora me traen el papeo. en una mano la currybrust y en la otra en phone. cachis! -bump
Mensajepor ron » 09 Sep 2017 00:28
El domingo por la tarde, miramos a ver de hacer algo. Antes de Amiga Wave.
