Progresos con el FP-1100
Anna Wu
Re: Progresos con el FP-1100
Mensajepor Anna Wu » 01 Mar 2015 20:47
Thanks for the info, Joscelyn!
Update:
https://www.sendspace.com/file/4u4x52
Available in .CAS/.WAV format and as Rampack.
PS: "POKER" seems too big for the Rampack unit.
Anna Wu
Mensajepor Anna Wu » 02 Mar 2015 06:13
Update 2:
https://www.sendspace.com/file/6ltwv9
PS: Press the Num keys (1,2,3...) to hit the ball.
Anna Wu
Mensajepor Anna Wu » 02 Mar 2015 16:56
@monkey390220 seems to be very active.
He added "SPACE SHOOTING" on his page.
Anna Wu
Mensajepor Anna Wu » 02 Mar 2015 18:40
Takeda-san released a new Common Source Code Project update (3/3/2015)
http://homepage3.nifty.com/takeda-toshiya/
He fixed the SCREEN 1 (VRAM)
CasioFP
Mensajepor CasioFP » 02 Mar 2015 18:42
Fantastic news !
640x400 resolution is back :)
Thank you Anna
Joscelyn
Anna Wu
Mensajepor Anna Wu » 02 Mar 2015 19:07
Joscelyn, take a look on the first screenshot. : )
http://homepage3.nifty.com/takeda-toshi ... index.html
Anna Wu
Mensajepor Anna Wu » 02 Mar 2015 19:15
I am looking for SELGA (PIO magazine)
viewtopic.php?p=200064429
Maybe someone can upload the source, scan (magazine) or the binary?
Agradecido : 2074 veces
Agradecimiento recibido: 1784 veces
Mensajepor ron » 02 Mar 2015 19:30
Anna Wu , the FTP is wrong: This is the right ftp: ftp://casio.ledudu.com/images/retrowiki
The problem is the user/pass, I dont have it :-(
The ledudu website does not provide links to download. http://casio.ledudu.com/pockets.asp?type=1805 and http://casio.ledudu.com/pockets.asp?type=2731
Anyway take a look, may be something over there...
Anna Wu
Mensajepor Anna Wu » 02 Mar 2015 19:42
Thanks for the info, Rodrigo. : )
CasioFP
Mensajepor CasioFP » 02 Mar 2015 19:43
Wow, all the RAM Packs are also back, wonderful !!
Thank you Anna and Takeda-san
@Anna: you got mail for Selga
CasioFP
Mensajepor CasioFP » 02 Mar 2015 22:52
Anna, you got a great idea of putting software in the RAMPACK.bin files.
Let me add two great machine language games of pure action !
First is Vegetable Crush ---> LINK : https://www.sendspace.com/file/85eb2d
RUN "PACK0:VEGCRA"
Second is Sea Monster ---> LINK : https://www.sendspace.com/file/hi97s1
RUN "PACK0:SEA"
CasioFP
Mensajepor CasioFP » 03 Mar 2015 00:11
I have tried inputting some machine language game listings but there is something off...
the hexadecimal function seems not to work properly anymore
So it is impossible to convert an hexadecimal value to poke values in memory
explanation : PRINT VAL("&HE960") should give 59744, but it does NOT : it displays -5792 instead
trying the reverse : PRINT HEX$(59744) does work and displays the correct result : E960
Only way to go ahead is to add 65536 to obtain the correct value, but this is dangerously error-prone
(which means needing to type in PRINT VAL&HE960)+65536 to obtain the correct value)
Joscelyn
Anna Wu
Mensajepor Anna Wu » 03 Mar 2015 08:43
I am not 100% sure the formatting of disk images is working or not.
1.) Mounted Disk.imd which contains some data on FD1 slot
2.) FORMAT "0:"
3.) FILES or FILES "0:"
4.) The disk is empty (temporary?)
5.) After exit of eFP-1100 a empty disk image will created called Disk.imd.D88
Agradecido : 245 veces
Agradecimiento recibido: 723 veces
Mensajepor jltursan » 05 Mar 2015 21:03
The formatting seems to work, as the D88 seems to be the native format of the emulator (IMD images need to create a temporary D88 image) its easier to handle.
Ive check the following:
1) A previously full disk image is formatted with "FORMAT 0:" and is emptied succesfully. "FILES 0:" reports no files.
2) I can load a RAMPACK file and save it to disk with SAVE "0:PROGRAM"
3) FILES doesnt not display the file :-(
4) Ive checked the image has been modified and the saved program can be seen inside it; but seems the FAT is wrong.
Btw, VEGCRA and SEAMON are impressive. Ill try to extract the binary to disassemble in the PC, I need to know how they achieved such speed; using the ROM routines seems unfeasible, theyre slooow.
Anna Wu
Mensajepor Anna Wu » 06 Mar 2015 12:37
monkey390220 added another BASIC program on his page.
http://www.geocities.jp/monkey390220/FP/index.html
Mensajepor jltursan » 06 Mar 2015 20:46
Ive been testing the SAVE feature on disk images. Ive created a a pair of blank disks (with eFP-1100 and the real machine) and saved the same tokenized program in both (again with the emu an the FP-1100):
10 PRINT "HELLO"
20 GOTO 10
The real image, once dumped, works fine in the emulator, the emulator one doesnt shows anything when doing a FILES command.
Comparing the images herere the differences (only one in the whole D88 file):
Real image/Emulator image
Ive attached both disk images. Maybe Takeda-San can work out the bug with these samples...
Disks.zip
FP-1100 example disk images
(8.9 KiB) Descargado 84 veces
Anna Wu
Mensajepor Anna Wu » 12 Mar 2015 01:48
Takeda-san released a new Common Source Code Project update (3/12/2015)
with "Save to Disk" fix (eFP-1100)
