Listado de componentes del NEWBRAIN por Colin Appleby
Agradecido : 1481 veces
Mensajepor ron » 15 Oct 2012 19:06
-conewbr
por Colin Appleby
NEWBRAIN COMPONENTS (Rev 4)
http://www.newbrain.info/resources/newb ... nents.html
Main Motherboard NB12117/A/7
Location   Component   Description
1   1N4733A Typical   5.1V Zener Diode 1 watt
2   820 ohms   Resistor
3   150 K ohms   Resistor
4   47 K ohms   Resistor
5   680 pF   Capacitor
6   22 uF 35V Elect   Capacitor Electrolytic
7   47 uF 16V Elect   Capacitor Electrolytic
8   2N5193   PNP Transistor (BD438, BD186, BD786)
9   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
10   4K7 ohms   Resistor
11   560 ohms   Resistor
12   680 pF   Capacitor
13   4K7 ohms   Resistor
14   41K2 ohms   Resistor
15   39K ohms   Resistor
16   4K7 ohms   Resistor
17   ZTX650   Transistor NPN Bipolar
18   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
19   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
20   ZTX107   Transistor Low current NPN Bipolar
21   ZN404   Precision Reference 2.45V ECB
22   2N5193   PNP Transistor (BD438, BD186, BD786)
23   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
24   1N4001   Diode Rectifier 1 Amp
25   1.2K ohms   Resistor
26   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
27   4K7 ohms   Resistor
28   100 ohms   Resistor
29   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
30   4K7 ohms   Resistor
31   IN4001   Diode Rectifier 1 Amp
32   56 ohms   Resistor
33   47 uF 16V Elect   Capacitor Electrolytic
34   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
35   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
36   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
37   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
38   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
39   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
40
41   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
42   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
43   47 ohms   Resistor
44   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
45   47 ohms   Resistor
46   1K2 ohms   Resistor
47
48   16MHz   16MHz Crystal SEI
49   BC546   Transistor NPN
50   100pF   Capacitor
51   27pF   Capacitor
52   47K ohms   Resistor
53   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
54   4K7 ohms X8 Multi   Resistor Multi Type
55   100pF   Capacitor
56   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
57   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
58   1K ohms   Resistor
59   4K7 ohms X8 Multi   Resistor Multi Type
60   1K ohms   Resistor
61   22K ohms Multi   Resistor Multi Type
62   120 ohms   Resistor
63   22 ohms   Resistor
64   33pF   Capacitor
65   220 ohms   Resistor
66   2N3906   Transistor PNP General Purpose
67   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
68   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
69   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
70   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
71   150 ohms   Resistor
72   220pF   Capacitor
73   470pF   Capacitor
74   2K ohms Variable   Resistor
75   2K ohms Variable   Resistor
76   22K ohms   Resistor
77   10 ohms   Resistor
78   22K ohms   Resistor
79   10 ohms   Resistor
80      Link
81   3.3 ohms   Resistor
82   0.47uF   Capacitor
83   47 ohms   Resistor
84   3.3 ohms   Resistor
85   0.47uF   Capacitor
86   47 ohms   Resistor
87   10nF   Capacitor
88   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
89   10nF   Capacitor
90   0.33uF   Capacitor
91
92   47K ohms   Resistor
93   1N4148   Diode for Switching and General purpose
94   47uF Elec   Capacitor Electrolytic
95   47uF Elec   Capacitor Electrolytic
96   1N4148   Diode for Switching and General purpose
97   33 ohms   Resistor
98   39K ohms   Resistor
99   39K ohms   Resistor
100   ZTX107   Transistor Low current NPN Ic=2mA Bipolar
101   10M ohms   Resistor
102   1K ohms   Resistor
103   680pF   Capacitor
104   47uF Elect   Capacitor Electrolytic
105   43 ohms   Resistor
106   1K ohms   Resistor
107   IN914   Diode High Speed, High Conductance
108   15K ohms   Resistor
109   IN914   Diode High Speed, High Conductance
110   ZTX212   Transistor Low Sat PNP
111   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
112   1K ohms   Resistor
113   4K7 ohms   Resistor
114   15K ohms   Resistor
115   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
116   68 ohms   Resistor
117   47uH +/- 10%   Inductor
118   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
119   47uF Elect   Capacitor Electrolytic
120   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
121   270 ohms   Resistor
122   75 ohms   Resistor
123   470 ohms   Resistor
124   150pF   Capacitor
125   10uF 25V Elect   Capacitor Electrolytic. Change to Tantalum
126   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
127   10uF 25V Elect   Capacitor Electrolytic. Change to Tantalum
128   220K ohms   Resistor
129   560K ohms   Resistor
130   0.1uF 50V   Capacitor Ceramic Monolithic Type 104
131   100 ohms   Resistor
132   680pF   Capacitor
133   470pF   Capacitor
134   4K7 ohms X8 Multi   Resistor Multi Type
401   CA358E   Amplifier same as LM358 Type
402   SN74LS153N   Dual 4-to-1 multiplexer
403   SN74LS153N   Dual 4-to-1 multiplexer
404   SN74LS153N   Dual 4-to-1 multiplexer
405   SN74LS153N   Dual 4-to-1 multiplexer
406   8250   UART Serial 9600 Bits/Second 40Pin DIL
407   Not populated
408   D23128C   PROM 28 Pin DIL
409   Z80 CPU   Microprocessor Z80
410   MC1489P   Quad RS232 Line Receiver
411   MC1488P   Quad RS232 Line Driver
412   SN74LS257AN   Quad 2 - input Multiplexer Tri-State
413   SN74LS174N   Hex D flip-flop with clear
414   CA358E   Amplifier
415   HAMLIN HE751A5409   DIL Relay
416   HAMLIN HE751A5409   DIL Relay
417   MM74C14N   Hex Schmitt Trigger (MC14584BCP)
418   DM7400N   Quad 2 Input NAND
419   COP420   COP Microcontroller
420   74LS374N   Octal D-Type Flip-Flop 3 State
421   74LS245N   Octal Bus Transceiver NonInv
422   74LS161AN   4-Bit binary counter
423   74LS161AN   4-Bit binary counter
424   74LS161AN   4-Bit binary counter
425   SN74LS74AN   Dual D-type flip-flop w/preset and clear
426   SN74LS86H   Quad 2 - input XOR gate
427   SN74LS174N   Hex D flip-flop with clear
428   SN74LS257AN   Quad 2 - input Multiplexer Tri-State
429   DM74LS139N   Dual 1-of-4 Dcdr Demultiplexer
430   SN74LS138N   1-of-8 Dcdr Demultiplexer
431   SN74LS32N   Quad 2 - input pos. OR gate
432   DM74LS04N   Hex inverter
433   SN74LS32M   Quad 2 - input pos. OR gate
434   DM74LS86N   Quad 2 - input XOR gate
435   SN74LS06N   Hex inverter buffer/driver
436   SN74LS166AN   8-bit par. Load shift register
437   SN74LS08N   Quad 2 - input AND gate
438   SN74LS08N   Quad 2 - input AND gate
439   DM74LS08N   Quad 2 - input AND gate
440   SN74LS02N   Quad 2 - input NOR gate
441   DM74LS00N   Quad 2 Input NAND
442   SN74LS138N   1-of-8 Dcdr Demultiplexer
443   DM74LS11N   Triple 3 - input AND gate
444   DM74LS157N   Quad 2-to-1 data selector/mux
445   SN74LS112AN   Dual J-K negative edge - Triggered Flip-Flop
446   SN74LS08N   Quad 2 - input AND gate
447   SN74LS393N   Dual 4BIT Binary Up Counter
448   DM74LS10N   Triple 3 - input NAND gate
449   DM74LS157N   Quad 2-to-1 data selector/mux
450   DM74LS04N   Hex inverter
451   DM74LS279N   Quad Set/Reset Latch
452   MC14584BCP   Hex Schmitt Trigger
453   EPROM 8248R7   NewBrain Character Set
454   SN74LS166AN   8-bit par. Load shift reqister
455   DM74LS27N   Triple 3 - input pos. NOR gate
456   SN74LS32N   Quad 2 - input pos. OR gate
457   DM74LS10N   Triple 3 - input NAND gate
458   SN74LS90N   Decade counter
459   SN74LS32N   Quad 2 - input pos. OR gate
460   SN74LS112AN   Dual J-K negative edge - Triggered Flip-Flop
461   SN74LS95BN   Shift Register Single Parallel I/O
462   SN74LS32N   Quad 2 - input pos. OR gate
463   SN74LS32N   Quad 2 - input pos. OR gate
464   DM74LS27N   Triple 3 - input pos. NOR gate
-conewbr
Volver a “NewBrain”
