Listado de componentes del NEWBRAIN por Colin Appleby
Agradecido : 1149 veces
Mensajepor ron » 13 Mar 2011 10:32
NEWBRAIN COMPONENTS (Rev 4)
Main Motherboard NB12117/A/7
Location
Component
Description
1
1N4733A Typical
5.1V Zener Diode 1 watt
2
820 ohms
Resistor
3
150 K ohms
Resistor
4
47 K ohms
Resistor
5
680 pF
Capacitor
6
22 uF 35V Elect
Capacitor Electrolytic
7
47 uF 16V Elect
8
2N5193
PNP Transistor (BD438, BD186, BD786)
9
0.1uF 50V
Capacitor Ceramic Monolithic Type 104
10
4K7 ohms
Resistor
11
560 ohms
Resistor
12
680 pF
Capacitor
13
4K7 ohms
Resistor
14
41K2 ohms
Resistor
15
39K ohms
Resistor
16
4K7 ohms
Resistor
17
ZTX650
Transistor NPN Bipolar
18
0.1uF 50V
19
0.1uF 50V
20
ZTX107
Transistor Low current NPN Bipolar
21
ZN404
Precision Reference 2.45V ECB
22
2N5193
23
0.1uF 50V
24
1N4001
Diode Rectifier 1 Amp
25
1.2K ohms
Resistor
26
0.1uF 50V
27
4K7 ohms
Resistor
28
100 ohms
Resistor
29
0.1uF 50V
30
4K7 ohms
Resistor
31
IN4001
32
56 ohms
Resistor
33
47 uF 16V Elect
34
0.1uF 50V
35
0.1uF 50V
36
0.1uF 50V
37
0.1uF 50V
38
0.1uF 50V
39
0.1uF 50V
40
41
0.1uF 50V
42
0.1uF 50V
43
47 ohms
Resistor
44
0.1uF 50V
45
47 ohms
Resistor
46
1K2 ohms
Resistor
47
48
16MHz
16MHz Crystal SEI
49
BC546
Transistor NPN
50
100pF
Capacitor
51
27pF
Capacitor
52
47K ohms
Resistor
53
0.1uF 50V
54
4K7 ohms X8 Multi
Resistor Multi Type
55
100pF
Capacitor
56
0.1uF 50V
57
0.1uF 50V
58
1K ohms
Resistor
59
4K7 ohms X8 Multi
Resistor Multi Type
60
1K ohms
Resistor
61
22K ohms Multi
Resistor Multi Type
62
120 ohms
Resistor
63
22 ohms
Resistor
64
33pF
Capacitor
65
220 ohms
Resistor
66
2N3906
Transistor PNP General Purpose
67
0.1uF 50V
68
0.1uF 50V
69
0.1uF 50V
70
0.1uF 50V
71
150 ohms
Resistor
72
220pF
Capacitor
73
470pF
Capacitor
74
2K ohms Variable
Resistor
75
2K ohms Variable
Resistor
76
22K ohms
Resistor
77
10 ohms
Resistor
78
22K ohms
Resistor
79
10 ohms
Resistor
80
Link
81
3.3 ohms
Resistor
82
0.47uF
Capacitor
83
47 ohms
Resistor
84
3.3 ohms
Resistor
85
0.47uF
Capacitor
86
47 ohms
Resistor
87
10nF
Capacitor
88
0.1uF 50V
89
10nF
Capacitor
90
0.33uF
Capacitor
91
92
47K ohms
Resistor
93
1N4148
Diode for Switching and General purpose
94
47uF Elec
95
47uF Elec
96
1N4148
97
33 ohms
Resistor
98
39K ohms
Resistor
99
39K ohms
Resistor
100
ZTX107
Transistor Low current NPN Ic=2mA Bipolar
101
10M ohms
Resistor
102
1K ohms
Resistor
103
680pF
Capacitor
104
47uF Elect
105
43 ohms
Resistor
106
1K ohms
Resistor
107
IN914
Diode High Speed, High Conductance
108
15K ohms
Resistor
109
IN914
110
ZTX212
Transistor Low Sat PNP
111
0.1uF 50V
112
1K ohms
Resistor
113
4K7 ohms
Resistor
114
15K ohms
Resistor
115
0.1uF 50V
116
68 ohms
Resistor
117
47uH +/- 10%
Inductor
118
0.1uF 50V
119
47uF Elect
120
0.1uF 50V
121
270 ohms
Resistor
122
75 ohms
Resistor
123
470 ohms
Resistor
124
150pF
Capacitor
125
10uF 25V Elect
Capacitor Electrolytic. Change to Tantalum
126
0.1uF 50V
127
10uF 25V Elect
128
220K ohms
Resistor
129
560K ohms
Resistor
130
0.1uF 50V
131
100 ohms
Resistor
132
680pF
Capacitor
133
470pF
Capacitor
134
4K7 ohms X8 Multi
Resistor Multi Type
401
CA358E
Amplifier same as LM358 Type
402
SN74LS153N
Dual 4-to-1 multiplexer
403
SN74LS153N
404
SN74LS153N
405
SN74LS153N
406
8250
UART Serial 9600 Bits/Second 40Pin DIL
407
Not populated
408
D23128C
PROM 28 Pin DIL
409
Z80 CPU
Microprocessor Z80
410
MC1489P
Quad RS232 Line Receiver
411
MC1488P
Quad RS232 Line Driver
412
SN74LS257AN
Quad 2 - input Multiplexer Tri-State
413
SN74LS174N
Hex D flip-flop with clear
414
CA358E
Amplifier
415
HAMLIN HE751A5409
DIL Relay
416
HAMLIN HE751A5409
DIL Relay
417
MM74C14N
Hex Schmitt Trigger (MC14584BCP)
418
DM7400N
Quad 2 Input NAND
419
COP420
COP Microcontroller
420
74LS374N
Octal D-Type Flip-Flop 3 State
421
74LS245N
Octal Bus Transceiver NonInv
422
74LS161AN
4-Bit binary counter
423
74LS161AN
424
74LS161AN
425
SN74LS74AN
Dual D-type flip-flop w/preset and clear
426
SN74LS86H
Quad 2 - input XOR gate
427
SN74LS174N
428
SN74LS257AN
429
DM74LS139N
Dual 1-of-4 Dcdr Demultiplexer
430
SN74LS138N
1-of-8 Dcdr Demultiplexer
431
SN74LS32N
Quad 2 - input pos. OR gate
432
DM74LS04N
Hex inverter
433
SN74LS32M
434
DM74LS86N
435
SN74LS06N
Hex inverter buffer/driver
436
SN74LS166AN
8-bit par. Load shift register
437
SN74LS08N
Quad 2 - input AND gate
438
SN74LS08N
439
DM74LS08N
440
SN74LS02N
Quad 2 - input NOR gate
441
DM74LS00N
Quad 2 Input NAND
442
SN74LS138N
443
DM74LS11N
Triple 3 - input AND gate
444
DM74LS157N
Quad 2-to-1 data selector/mux
445
SN74LS112AN
Dual J-K negative edge - Triggered Flip-Flop
446
SN74LS08N
447
SN74LS393N
Dual 4BIT Binary Up Counter
448
DM74LS10N
Triple 3 - input NAND gate
449
DM74LS157N
450
DM74LS04N
Hex inverter
451
DM74LS279N
Quad Set/Reset Latch
452
MC14584BCP
Hex Schmitt Trigger
453
EPROM 8248R7
NewBrain Character Set
454
SN74LS166AN
8-bit par. Load shift reqister
455
DM74LS27N
Triple 3 - input pos. NOR gate
456
SN74LS32N
457
DM74LS10N
458
SN74LS90N
Decade counter
459
SN74LS32N
460
SN74LS112AN
461
SN74LS95BN
Shift Register Single Parallel I/O
462
SN74LS32N
463
SN74LS32N
464
DM74LS27N
Volver a “NewBrain”
