VBXE ejemplos
Agradecido : 264 veces
Agradecimiento recibido: 180 veces
VBXE ejemplos
Mensajepor Nandove » 13 Sep 2017 19:55
Segun vaya encontrando codigo de ejemplos de la VBXE ire añadiendo aqui los resultados:
10 V=214*256
20 MEMCONTROL=V+94
30 MEMBANK=V+95
40 POKE MEMCONTROL,128+8:REM $8000, 4K, CPU ACCESS
50 POKE MEMBANK,128+0:REM BANK 0
60 XDL=32768
70 POKE XDL,40:REM COLORMAP ON, REPEAT
80 POKE XDL+1,14:REM SET MAP ADR/STEP, SET MAP PARAMETERS, SET ATTRIBUTES
90 POKE XDL+2,7:REM REPEAT 7 MORE
100 POKE XDL+3,0:POKE XDL+4,16:POKE XDL+5,0:REM ADR $4000 IN VBXE FOR COLORMAP
110 POKE XDL+6,160:POKE XDL+7,0:REM STEP BY 160 BYTES
115 POKE XDL+8,0:POKE XDL+9,0:POKE XDL+10,7:POKE XDL+11,7:REM H/VSCROL, MAP CELL SIZE
117 POKE XDL+12,2:POKE XDL+13,255:REM NORMAL WIDTH, OVERLAY PRIORITY>GTIA
120 FOR A=XDL+14 TO XDL+14+3*10 STEP 3
130 POKE A,40:REM COLORMAP/REPEAT
140 POKE A+1,0:POKE A+2,7:REM REPEAT 7
150 NEXT A
160 POKE A,0:POKE A+1,128:REM JVB
170 POKE MEMBANK,128+1:REM BANK 1
175 BC=0
176 REM GOTO 300
180 FOR Y=0 TO 12:CS=32768+Y*160:LUM=6:LS=1
185 FOR X=0 TO 39
190 C=CS+X*4
200 POKE C,0:REM PF0
210 POKE C+1,LUM:REM PF1
215 LUM=LUM+LS:IF LUM=15 OR LUM=6 THEN LS=-LS
220 POKE C+2,BC:BC=BC+16:IF BC>255 THEN BC=BC-255
225 POKE C+3,0
230 NEXT X
240 NEXT Y
300 POKE V+65,0:POKE V+66,0:POKE V+67,0:REM SET XDL ADDRESS
310 POKE V+64,3:REM ENABLE XDL, EXT COLOR
Lento de cohones ejecutar desde basic.
Volver a “Software Atari 8 Bit”
