[English] OS-9 L1 v1.2
Agradecido : 477 veces
Agradecimiento recibido: 591 veces
Re: [English] OS-9 L1 v1.2
Mensajepor pser1 » 31 Jul 2017 12:08
jltursan escribió:I've been booting it (FLEX 3.01) from 5.25", originally in the FM-7 and now in the FM77AV without problems. The only flaw is that "DRIVES NOT READY" after some time...
I a getting angry with myself, damn it! -banghead
I am unable to boot / start FLEX301 nor can I boot FLEX311, so I must be doing something really wrong!
I have tried both disks on XM7 emulating a std FM-7 choosing "Files / Basic mode"
and later choosing "Files / DOS mode", none of them show a bit on the screen after pressing "F12" or "Alt+F12"
I start FM-7 with an F-Basic disk, that works well, then I insert any of the FLEX disks and try DOS, BOOT and nothing good happens (Syntax Error)
After both Resets (soft and hard) no response ... just the white square flashing top left
What is the exact procedure I should apply to get it started? -nb -nb
Thanks in advance
Mensajepor pser1 » 31 Jul 2017 17:14
jltursan escribió:Check malikto999's post from 23 Jul 2017 03:48 in first page ;-)
OK, tested and works like a charm!
Would it be kind of a problem if we leave this box checked (insert wait during floppy access)? ...
- Answer to myself: Yes, it slows down the screen loading in Tiburón/Shark!
cheers
Volver a “Fujitsu FM7”
