Bios ( ROM ) de Camputers Lynx [buscando versiones]
Peter Todd
Mensajepor Peter Todd » 03 Ene 2014 23:18
I am trying to get as many versions of the Lynx ROMS as possible.
Please if you have a Lynx 48 or 96 or 128 could you upload the ROM image to this thread so I can check it against the ones I have already.
Thank You
Peter
Agradecido : 1185 veces
Agradecimiento recibido: 1206 veces
Re: ROMS HERE
Mensajepor ron » 03 Ene 2014 23:29
Have you tryed these:
lynx48k.zip
(24.5 KiB) Descargado 219 veces
lynx96k.zip
(21.49 KiB) Descargado 227 veces
lynx128k.zip
(24.24 KiB) Descargado 230 veces
Peter Todd
Re: Bios ( ROM ) de Camputers Lynx [buscando versiones]
Mensajepor Peter Todd » 04 Ene 2014 04:35
Thanks ron Il check these against what I have - they look like the 4 sets of PALE ones that I have already though.
I have:
2 x 48k
3 x 96k
2 x 128k
sets. I will get checksums for them and post here tomorrow.
Best Regards!
Pete
Agradecido : 134 veces
Mensajepor jltursan » 04 Ene 2014 13:06
I suposse my ROM images are the ones you can easily find in the web (most probably downloaded from your page); but, is there a way to dump the real one?. I havent checked it yet; but if the ROM is socketed I can dump it easily, if not, Ill need to save it to tape.
Peter Todd
Mensajepor Peter Todd » 04 Ene 2014 20:28
Hi yes I suppose I should have said not from emulators . You could also just check the roms from pale against the ones in your machine.
In fact... Thinking about it. ... I might write a little program to checksum the users rom and then we can just check whether we have their rom already.
I am interested in any roms which are different to those from pale, or any roms which have been produced by third parties. For example I have a Scorpion ROM in one of my 96k machines.
Mensajepor jltursan » 05 Ene 2014 18:53
Herere my own ROMs...
Ive found that theyre the same as found in the 96K model. Comparing them with the ones you provided with Pale:
Lynx48K_JL.zip
(12.31 KiB) Descargado 223 veces
lynx96-1.rom = Lynx48K_IC46.rom
lynx96-2.rom = Lynx48K_IC45.rom (except last byte, $FF instead $00)
Peter Todd
Mensajepor Peter Todd » 06 Ene 2014 01:29
ah excellent final confirmation that the final byte in the Pale rom is incorrect - I always thought it looked a bit odd. I will recheck the original
that I received. Thanks very much for uploading the set.
So far I have
48k Rev 1
48k Rev 2.0
96k ROM 3 Rev ? have to check
128k ROM Rev ? I suspect 1.0
128k ROM Rev ? 1.0 modded by M Smith
Ill take some checksums and see about a little check program.
Pete
Mensajepor jltursan » 06 Ene 2014 12:17
Yep, I was thinking about a simple CRC check BASIC program (well, maybe with some assembler help...)
Volver a “Camputers Lynx”
