TAP2WAV para Camputers Lynx. Conseguido !!!
Peter Todd
Re: TAP2WAV para Camputers Lynx. Conseguido !!!
Mensajepor Peter Todd » 04 Ene 2014 04:25
I have put up a cleaned up version which also includes a Media Player to play the wave
http://camputerslynx.info/PALE/
VERSION 8.50 EXE and DLL Update
OK Bed time!!!!
weirdocollector
Mensajepor weirdocollector » 04 Ene 2014 10:45
Sleep well Pete!
Youve earned it :)
Thanks a lot for everything!
Inviato dal mio GT-I9300 utilizzando Tapatalk
Agradecido : 199 veces
Agradecimiento recibido: 590 veces
Mensajepor jltursan » 04 Ene 2014 13:02
Hey, thats what I call a cool way to start a new year!, great news indeed!
Thanks Peter & Ron for you efforts!
Descargado el PALE 8.50, ahora a ver si saco tiempo y lo pruebo en el Lynx :-)
Peter Todd
Mensajepor Peter Todd » 04 Ene 2014 13:24
I shall have a look at the 128 TAP as well.
There are a few TAP files which will not work because they have a bad read off the old tapes - bad header bytes etc.
I will also alter it to deal with headerless files as in Level9 and others (SPLYNX DeltaWing)
Peter Todd
Mensajepor Peter Todd » 04 Ene 2014 13:55
Hey thats a great Project you have going there Wierdo! Lovely to see the TMS being used for the video, I have been looking at using one for
MSX compatibility in my SuperLynx project.
Agradecido : 1788 veces
Agradecimiento recibido: 1535 veces
Mensajepor ron » 04 Ene 2014 19:22
Hi there
I think the best we can do is open a new thread in order to discuss the expansion memory to 96K, and let this one dedicated exclusively for tape conversion.
There are other colleagues who have the 96K version and probably would need a good look. I would like to upgrade my Lynx too.
So, I would like to invite for open a new thread, its necessary and very interesting. Do you agree with this ?
Hola Troncos !!!
Creo que lo mejor que podemos hacer es abrir un hilo nuevo dedicado enteramente a la ampliación del Lynx a 96K. Yo mismo quisiera ampliar el mio.
A otros colegas como Garillete que tienen un 96 les vendría muy bien para revisar los fallos que presenta, y de paso echarle un buen vistazo.
Así que os invito a abrir un hilo dedicado enteramente a la ampliación a 96 K y dejamos este exclusivamente para hablar de la conversión de TAP a Wav
¿ Os parece bien ?
Peter Todd
Mensajepor Peter Todd » 04 Ene 2014 20:15
Go for it Ron, your Spanish would be better than mine .
The site with all the info on isnt mine it belongs to another lynx nut, my own site is down while I move house.
Ill tell him about the broken link.
Peter Todd
Mensajepor Peter Todd » 04 Ene 2014 20:18
I have a ROM disassembly that I did while writing the emulator, I will post it here later.
Mensajepor ron » 04 Ene 2014 23:12
Ahora ya solo queda que Blackhole desarrolle la brillante idea que tiene. Pasar los TAP a TZX, ya iba a ser la repera.
weirdocollector
Mensajepor weirdocollector » 04 Ene 2014 23:49
Peter Todd escribió:Hey thats a great Project you have going there Wierdo! Lovely to see the TMS being used for the video, I have been looking at using one for
Thanks Pete for your interest!
The TMS is fairly powerful, and easy to interface and program.
For my next project, Im thinking about using a 9958, the VDP used in the MSX2 computers.
Peter Todd
Mensajepor Peter Todd » 05 Ene 2014 02:39
Ron did you have any problems installing the latest updates ? any problems with the Network and Serial OCX files (they arent included in the setup)
Peter Todd
Mensajepor Peter Todd » 05 Ene 2014 04:33
Oh and it would be MUCH better if we had a proper external TAP2WAV along the lines of what blackHOle is suggesting, it would
be more reliable and do all the tape speeds etc. and also be downright more elegant than my hack together :)
Are you thinking of the conversion from T-state to sample time from your info then with the addition of a little sin interpol to get
a more realistic waveform we end up with a nice little standalone DOS? program?
Peter
Mensajepor ron » 05 Ene 2014 09:26
No Pete, I had not any problem. For me PALE runs perfectly.
May be that Im not using ( at the moment ) Network nor Serial , but the main purpose works fine. And the path is not the same of the main installation.
Mensajepor ron » 05 Ene 2014 09:53
Peter Todd escribió:Oh and it would be MUCH better if we had a proper external TAP2WAV along the lines of what blackHOle is suggesting, it would be more reliable and do all the tape speeds etc. and also be downright more elegant than my hack together :)
Peter
According to the explanations of BlackHoles idea, there are two options. Using the emulator or having a single program isolated from PALE, even in DOS. As happens with Dragon, Oric, etc ... not even necessarily have to be a native WIn32 app , you can even use the DOSbox (will work under emulation with other platforms as Linux or MacOS.
The main goal is achieved, now the conversion works and its a question of time deploying the tool. And converting TAP to TZX will allow us to play from any of the programs that already exist, now we have the way to do it.
Volver a “Camputers Lynx”
