Pequeño problema con las bandejas lector CD
Fidelware
Agradecido : 10 veces
Mensajepor Fidelware » 15 Dic 2018 08:14
Os necesito, el ibook G4 no expulsa un cd que tiene dentro, y he probado todas las combinaciones de google, y el imac g4 no me abre la bandeja de su CD, alguna sugerencia que no implique desmontar todo?
Awesome since 1982
Agradecido : 223 veces
Agradecimiento recibido: 654 veces
Re: Pequeño problema con las bandejas lector CD
Mensajepor jltursan » 15 Dic 2018 09:22
De la guía oficial de Apple:
Mac OS X
In the Finder, Choose View > Customize Toolbar. In the window that appears, drag the Eject button to the toolbar, then click Done. Select the disc you want to eject in the Finder window, then click the Eject button in the toolbar.
Press the Eject key on the Apple Pro Keyboard.
To open the second optical drive on a Power Mac G4 (Mirrored Drive Doors) computer, press Option-Eject on the Apple Pro Keyboard.
If you have a keyboard without an eject key, press F12 (under Mac OS X 10.1 and later). Note: You must press the F12 key longer to prevent the tray from accidentally opening.
Click the eject button in iTunes (illustrated in Figure 1).
Hold down the mouse button when you hear the startup sound as the computer restarts.
Start up from Mac OS 9.2 and follow the options in the section above.
If the computer is not responding
Restart the computer and hold down the mouse button when you hear the startup sound.
Restart the computer, hold down the Option key, and use the startup manager to open the tray.
Choose a different operating system in the startup manager, and eject the CD using the steps above.
Insert a paper clip into the manual eject hole, which is located on the bottom right or left side of the drive (depending on the model), under the bezel. A paper clip inserted into this hole unlatches the drive. Next, bend the paper clip into a hook and put it under the drive's tray. You should be able to pull the tray out at this point.
During startup, press and hold the Command-Option-O-F key combination to enter Open Firmware, type "eject cd" in lower case letters, then press return.
Agradecido : 3002 veces
Agradecimiento recibido: 1266 veces
Mensajepor minter » 15 Dic 2018 11:06
Si no te funciona lo del clip... Es que se te ha salido el CD del sitio. Me ha pasado en un par de ocasiones. Puf!
Redwind
Mensajepor Redwind » 15 Dic 2018 12:53
Hola. Arranca el equipo con la tecla ESC pulsada todo el tiempo, y si asi no funciona, lo mismo pero con la tecla de expulsion de CD. Creo que esos eran los metodos de expulsion de emergeencia.
Fidelware
Mensajepor Fidelware » 20 Dic 2018 22:21
Nada me toca desmontar
Awesome since 1982
Volver a “Macintosh”
