Supongo que terminare haciendo eso de la Gotek,pero tardare un poco,hasta la siguiente rabieta...voy tirando el dinero asi poco a poco,cuando me entra la locura...,hoy la FDD externa de aqui un mes la Gotek...me voy dosificando.
creo que la FDD externa esta la podria utilizar de arma Roma,tiene el cable muy largo y es bastante maciza (˘⌣˘ )
Edit:
esto es lo que me han dicho en grupo Ingles,creo que he afinado mas la pregunta...
mi pregunta:
Hi all,i have a question,thanks in advance.
Can I run games from an external floppy drive "DF1"in my Amiga 1200?,for now i have no luck trying,I try to disable the DFO "in my A1200 there is none, it broke down years ago"and i use HDD for everything,the floppy seems to read,but a message "not DOS in DF1"appears,so is possible execute games in this way or not?
Respuesta:
In short - no. Although initially with KS2+ you can boot from an external drive, they're hard coded to use the internal drive df0: so while it'll boot, it won't be long until it tries to access df0:
