Pro-DOS 2.0 [CP/M] todo en un solo disco !!!
Agradecido : 1487 veces
Agradecimiento recibido: 1244 veces
Mensajepor ron » 01 May 2015 12:53
Chris Pile ha hecho magia y yo sin probar nada !!! -banghead .
Ahora ya no es necesario usar un disco de BOOT y otro de SYSTEM como sucedía en la versión 1.9, además que era un rollazo pasar esas imágenes a floppy porque ninguna iba bien.
Ahora viene todo en el mismo floppy. Directamente podemos botar y hacerlo de varias formas.
Entre las novedades ( Verano 2014 )
[tabs][tabs: ] Better CP/M 2.2 compatibility
Up to eight simultaneously visible disk drives - Drives A:through to H:
Compact Flash support using the ATOM-Lite (right-hand drive bay)
Dual CF adapter support in the ATOM-Lite - seen as two separate drives
MMC/SD/SDHC flash support using Quazar's Trinity Ethernet Interface
100% compatible with the AL-Patch format
Pro-DOS can optionally boot from its own format 720k CP/M disks
If your SAM has an AL-BOOT ROM Pro-DOS can also boot from CF cards
Up to 64-Gigabytes (65535 logical disks) on CF/MMC/SD/SDHC cards
Will use any external RAM packs to provide up to four 1MB RAM Drives
Improved performance, with particular attention paid to screen output
More accurate Heath/Zenith H19/Z19/DEC VT52 terminal emulation
Better command-line editing functions
Command-line can accept user areas - so DIR A4:*.COM is valid
Can simultaneously change drives and user areas at the command prompt
MS-DOS-like command history buffer for the eight most recent commands
Retro green-screen look with funky flashing cursor - changeable of course!
Will save/restore your chosen screen colours to/from the Trinity EEPROM
System bell sound makes a better "ding" and no longer pauses the system
The DIR command now outputs in alphabetically sorted columns
Better memory use to allow v2.0 to retain v1.9's internal RAM Drive sizes
A large (63238 byte) Transient Program Area for external programs
The separate system files disk used by v1.9 is no longer required
All system files are pre-installed to the internal RAM Drive at boot
COPY and DUMP commands are now built-in, and not external programs
All internal commands accept wildcards, including REName and COPY
Ability to software-swap a pair of drives, so A:can be B:and vice versa
FATREAD.COM for importing files from PC formatted FAT12/16/32 media[/tabs]
y FINALMENTE PROBADO !!!
Ahora da gusto, tener al menos una versión totalmente funcional y tan mejorada. Solo resta empezar a mirar de probar el software que me gusta ya que opciones hay muchas.
http://www.samcoupe-pro-dos.co.uk/prodosdisk.html
Volver a “Sam Coupé”
