¿ Hay aplicaciones CP/M disponibles para Sam Coupé ?
Agradecido : 1477 veces
Agradecimiento recibido: 1468 veces
Mensajepor ron » 23 Abr 2013 22:29
Que pasa ! aquí preguntaba si alguien conoce algún site en donde se puedan encontrar las aplicaciones clásicas CP/M [ léase WordStar, TurboPascal, etc... ] ya en imagen con formato Sam , aunque sean para ejecutarlas bajo Pro-DOS
Ya en si, cargar el Pro-DOS es un poco lío, requiere de dos floppies, uno de boot y el otro de System.
Pero supuestamente una aplicación CP/M debería poderse ejecutar sin problema, ese es el punto al que quiero llegar. Si alguien ya lo ha probado que lo comente. Mi idea era inyectar los ejecutables y los ficheros de programa en una imagen de disco y volcarla a floppy real para usar con el Sam.
Pro-DOS could be thought of as a Disk Operating System (DOS), However, it is more than this, it is a full Operating System that Provides compatibility with CP/M 2.2.
In simple terms this means that a whole world of software that was designed to run under CP/M 2.2. will now run on the SAM Coupé. Pro-DOS uses the same Disk format as the Amstrad PCW 8256 and, as a result, it can read disks from this machine direct, this also Means that there is a vast range of software already available from sources such as Public Domain libraries.
When buying software from a public domain library you must check that it was designed to run under CP/M 2.2 or one of the lower versions, 1.4 for example. Some software will only run under the later versions of CP/M, commonly known as CP/M 3 or CP/M Plus. However, the majority of available software is 2.2 compatible and you should have no trouble running it under Pro-DOS. Some software may need "installing" for the particular machine you intent to run it on, this normally involves terminal (or screen) configuration and sometimes disk data information, most Software includes full configuration instructions and it is usually a simple task.
gracias ! a ver si sale algo !
Re: ¿ Hay aplicaciones CP/M disponibles para Sam Coupé ?
Mensajepor ron » 03 May 2013 20:08
Le hago un -tatice_01 al hilo de -cosam a ver si -harp -fisch
-1832 -mfr_lol
y si no, pues hay alguna utilidad buena para crear / editar imágenes de disco de -cosam ?
Mensajepor ron » 03 May 2013 20:27
Me autorespondo, porque lo tengo delante, si hay más programas que este y los conocéis, agradezco la info.
Sobre todo para editar formato proDOS, voy a mirar en las linuxtools a ver si viene.
Mensajepor ron » 03 May 2013 20:30
Volver a “Sam Coupé”
