Cobado M6809 Micro BIOS/Server CoCo Server
luiscoco
Agradecido : 37 veces
Mensajepor luiscoco » 18 Ago 2017 06:39
La misma persona que hizo el IDE CMOC para windows (buzzphp), hizo esto, Aun no lo termino de entender
https://sourceforge.net/projects/cobado/
A Colour Computer (M6809) BIOS for interfacing to remote file systems
Description
Just for fun, I entered Cobado in the Retrochallenge Content. There are some great projects running:
http://www.wickensonline.co.uk/retrocha ... ants-list/
Cobado is a "CoCo Backdoor BIOS". The idea is to run an ultra small generic BIOS on a Colour Computer which can be used to add full remote file access to a Windows system.
The BIOS is under 255 bytes and fits into the cassette buffer. It hooks into the CoCo's line input (vector 12) and returns the command line to the server via the Becker port. The server is then able to take over the CoCo to provide any command set it chooses.
Currently you can navigate Windows, load/save BASIC & binary programs.
The next version will replace the Becker port with RS232, so the system will run on a stock standard Colour Computer.
Future versions will enable executing system commands. ie: Assemblers, compilers, etc. This will enable fast, safe, software development within the CoCo environment.
Cobado M6809 Micro BIOS/Server Web Site
Categories
Features
Remote TCP Server
Ultra Small 6809 BIOS
Tape Loadable BIOS
Portable to other 6809 (and maybe 6502) systems
Read Me
// Cobado - A CoCo Back Door (keylogger) [All for good reasons]
// The idea of Cobado came to me tonight. I wanted a simple system for
// accessing Windows though a CoCo. Ive been playing with the Becker port
// for a few days, and then it all came together. Why not write a remote
// control interface, which can be controled via a TCP server?
// Cobado hooks into the chrout of the CoCo. It then monitors the keypresses
// and records a buffer of the current command line. When you press enter,
// Cobado is able to intercept and start doing stuff to the CoCo. ie: Poke
// memory, write text, move memory, clear memory, get memory, put memory,
// etc, etc. ie: remote controlling. Once the Cobado server is done,
// control returns to the CoCo, and Cobado waits for more keypresses.
// The system enables you to intercept the command line, and add new commands
// to the CoCo... remotely. There is no need to install, patch, modify the
// ROM, or load in a new DOS.
// Ive only just started to play with this idea, but it should be able todo
// anything. You can even put code into the CoCo's memory, and execute it.
// If I get this working the way I want, you should be able to
// extend a basic CoCo 1,2,3 DOS/NO DOS, even maybe a Dragon, without adding
// more code to the system. I might even be able to run remote app's though
// the CoCo display system.
// Eventually, I want a RS232 version of this idea. Im using the Becker Port
// ATM because VCC/XRoar dont support serial comunications.
https://youtu.be/2kwnv9IsBhw
Agradecido : 471 veces
Agradecimiento recibido: 583 veces
Re: Cobado M6809 Micro BIOS/Server CoCo Server
Mensajepor pser1 » 18 Ago 2017 12:27
Buenos días Luis,
genial, otro mas!
Realmente es muy interesante como proyecto ...
De todas formas la comunidad CoCo está mas que contenta con su Drivewire que les permite iniciar incluso NitrOS-9
Esto sin tener en cuenta que las nuevas tecnologías han aportado soluciones mucho mas simples e integradas como
- CoCo-SDC - Todo lo que necesites lo metes en la tarjeta y navegas en ella con la aplicación de CoCo: SDCX (Guillaume Major)
- CoCo-Flash otra alternativa com 8Mb de FlashRAM que permite grabar incluso ROMs super grandes como RoboCop (128k)
y ejecutarlas sin problemas, de nuevo sin cables hacia PC ó Mac, también lleva un menú para seleccionar lo que se quiere ejecutar.
Ya de paso mencionar que lo del CoCo-SDC también existe para Dragón ya que Guillaume mantiene una versión de su navegador
para ambos ordenadores.
En cuanto al CoCo-Flash para Dragón habrá que esperar ... yo he pedido uno y veré si se puede hacer algo parecido al CoCo-SDC para Dragón
El fabricante Jim Brain (Retroinnovations) me ha dicho que me facilitará toda la información técnica del módulo (microcontrolador y protocolo
de comunicación que admite el mismo) tal como en su momento hizo Darren Atkinson para permitirme hacer las utilidades que gestionan el
CoCo-SDC desde el DOSPlus5.0 extendido
Volver a “Tandy CoCo”
