AspeQt v1.0.0 Preview-6 ( Atari serial peripheral emulator )
Agradecido : 1788 veces
Agradecimiento recibido: 1535 veces
Mensajepor ron » 14 Jun 2014 12:07
Acabo de descubrir una interesante herramienta si tienes un Atari de 8 bit. Ya os estáis haciendo con un cable SIO2PC porque esto tiene muy buena pinta. Con AspeQt y un cable SIO2PC podrás emular mogollón de dispositivos SIO desde tu PC:
[tabs][tabs: ]Up to 15 disk drive emulation with hide/show drive groups and mini mode option
Up to 6 x SIO speed (125,000bps)
Support for ATR, XFD, PRO and ATX (VAPI) disk images
Mount folders as emulated disks, allows booting various DOSes from folders
Disk image explorer with drag and drop support allows disk image manipulation
Directly boot Atari executables with option for multiple-reboots
Text only printer emulation with PC print, save, and ATASCII font support
Cassette image playback at normal or high-speed
Multilingual GUI (English, Polish, Slovak, German, Spanish, Turkish and Russian)
AspeQt client module (AspeCl) for Atari, communicates with the server and performs a variety of remote operations
And more.....[/tabs]
[tabs][tabs: ]Cross-platform GUI with drag and drop support.
15 emulated disk drives with support for 512 bytes per sector disk images.
High speed operation up to 6 times faster than the normal speed (With compatible OS / DOS)
Ability to use PC folders as emulated disks.
Disk image explorer for viewing and modifying disk image contents.
Ability to run Atari executables directly without using disc images and Doses.
Printer emulation with preview and ATASCII support.
Cassette image playback with custom baud rate.
Ability to save and restore AspeQt sessions with its UI settings..=
Normal and mini UI modes.[/tabs]
Más info y descargas: http://sourceforge.net/projects/aspeqt/
Agradecido : 18 veces
Re: AspeQt v1.0.0 Preview-6 ( Atari serial peripheral emulat
Mensajepor Taburoto » 15 Jun 2014 18:48
AspeQt es la herramienta que utilizo para darle de comer a mi 800XL con un cable SIO2PC,hay otras herramientas,pero a mi solo me funcionó con esta.
En su dia cuando monté el cable me volví loco intentando hacer funcionar el APE (el soft que recomiendan en los foros de Atari) pero por suerte encontré este AspeQt.
SIO2PC Taburoto
Volver a “Atari 8 Bit”
