Dicen las crónicas:
The VIC-20 was initially launched in Japan in late 1980 (under the ‘VIC-1001’ name) with a Japanese 'Katakana' set of characters. It was subsequently released in North America in May of 1981. Though these are the "official" release dates, several prototypes of the Commodore VIC-20 were reportedly available in late 1979. These early machines offered only 4 KB of RAM and used a different set of game cartridges.
Aunque estas son las fechas oficiales de lanzamiento, según varios informes disponibles hubo varios prototipos de Vic20 disponibles a finales de 1979. Estas primeras máquinas ofrecían tan solo 4 Kb de RAM y utilizaba un conjunto diferente de cartuchos de juegos.
En otros casos:
The VIC-20 debuted in June of 1980 at the Computer Electronics Show but its development started almost by accident two years earlier. Commodore engineered and manufactured the "Video Interface Chip 6506" or VIC1 for the video game market which was beginning to collapse. After not being able to sell the chip, Commodore developed the VIC-20 as an inexpensive home computer. Between early 1981, when the VIC actually hit store shelves, and the first few months of 1985, when the last VIC production line was shut down, it had sold more than 2.5 million units. It had an very impressive peak daily production of 9000 units and was the worlds first computer to sell more than 1 million units.
Estábamos celebrando el trigésimo aniversario durante este 2011 y no se si le habremos dado el mismo trato que se la ha dado al BBC Micro, por poner un ejemplo.
Aunque el motivo del post no es otro que valorar si el VIC20 es pionero y me explico:
Los primeros prototipos se ven en 1979 y en 1980 se comercializa en Japón. Es anterior a muchas cosas que se van viendo, llevo tiempo comentándolo y no se si debemos ser más rigurosos en cuanto a ello.
Lo importante es valorar la máquina porque es realmente avanzada en cuanto a sus competidores, y si, hay un detalle, se nota que en cuanto a video se quedó un poco en los 70 en cuanto a formas y tamaños, pero hasta 1985 se podía adquirir un Vic20 en muchos sitios y había aun cosas, cartuchos, cintas...
Propongo arrancar el martes un Micro de La Semana protagonizado por el VIC20.
En la Biblioteca de Divulgación Científica Muy Interesante, exactamente en el tomo tres del Libro básico del ordenador Personal, publicado en 1986, hay una referencia al VIC-20. Por su singularidad es de obligada referencia, para que los que, aún no lo saben, tengan una idea de lo que ha evolucionado la informática (y la tecnología en general) en los últimos treinta años.
El VIC-20 ha sido uno de los micros más vendidos en los últimos años: mas de un millón de unidades en todo el mundo según Commodore. Atrae básicamente a los que compran un ordenador por primera vez y a los entusiastas de los juegos, pues el tamaño de su RAM, 5 k, es demasiado reducido para aplicaciones serias. El VIC-20 es compatible en software con la gama PET, hoy ya obsoleta, y por ello los usuarios pueden usar gran cantidad de software creado para los primeros micros y adaptar los programas para aprovechar las posibildades del VIC, tales como el color y los gráficos de alta resolución.
El VIC-20 consta de una única unidad de teclado en cuyo interior se alojan los chips de la CPU y la memoria. El sistema operativo y un intérprete de Basic van en ROM. Para entrada – salida cuenta con conexión a un televisor o a un monitor, ranura para cartuchos, conector para módem y puerto para joystick o palanca de rótula.
Los usuarios suelen guardar sus programas en magnetófono, aunque también se puede conectar una unidad de disco de 51/4 pulgadas.
Especificaciones técnicas
HARDWARE
CPU 6502
RAM 5k ampliables a 29
ROM. Sistema operativo e intérprete de Basic en ROM
Pantalla. 23 líneas x 22 caracteres con gráficos de bloque, 8 colores de borde, 16 colores de pantalla, 8 colores de caracteres, cartucho opcional para gráficos de alta resolución 176×158
Teclado. 66 teclas, incluyendo control de cursor y cuatro teclas programables
E/S. Interfaces para magnetófono, joystick y módem, salida para televisor VHF, conector de expansión RAM externa y cartuchos, puerto para impresora y unidad de disco
SOFTWARE
Sistema operativo. Propio de Commodore en ROM.
Lenguaje. Basic en ROM
Aplicaciones. Amplia gama de juegos y software domético en general, algunos paquetes de gestión “de poca monta”
Lo del "de poca monta" a saber si quien lo redactó tenía claras las limitaciones de video y memoria, tengo la impresión que si, porque realmente y reconozcamos que en un VIC20 el tratamiento de textos y el uso de tablas es para personas como yo que tenemos alguna dioctría y necesitan video a lo grande.
Y no os perdáis este FAQ:
VIC 20 Personal Computer
1. Q: Can VICMON and the Super Expander be used at the same time with the expansion module?
A: No. Although some functions may operate correctly, some memory
locations in each cartridge are the same, which would interfere with programming.
2. Q: Can scrolling be made to reverse itself on the VIC 20?
A: It is possible to make scrolling reverse itself with a machine language routine. However, there is no routine located in ROM that will accomplish this. The routine must be developed by individuals who wish to make scrolling reverse itself.
3. Q: Are any commands assigned to function keys in the Programmer's Aid Cartridge?
A: Yes. There are two sets of commands assigned to the function keys in the Programmer's Aid Cartridge. However, these commands can be
redefined.
4. Q: Is it possible to restore the VIC back to the unexpanded VIC with the expander cartridges plugged in?
A: No, it is not possible to restore the VIC back to the unexpanded VIC with the expander cartridges plugged in. The cartridges must be un-plugged to restore the VIC back to its unexpanded mode.
5. Q: What controls the clock on the serial I/O port of the VIC 20?
A: The 6522 chip in the VIC has a crystal clock in it which controls the rate of transfer on the serial I/O port.
6. Q: Where is the start of BASIC located when the 8K and 16K Memory Expander cartridges are plugged in?
A: BASIC starts at 4096 decimal with the 8K and 16K Memory Expander cartridges plugged in.
7. Q: Is the user port of the VIC 20 analog or digital?
A: The user port of the VIC 20 is digital.
8. Q: How much usable memory is available of the full 32K RAM in the VIC?
A: There is 27 1/2 K usable memory available.
9. Q: How can screen memory be moved around on the VIC 20?
A: Screen memory can be moved around by altering the upper four bits of location 36869. This is the screen memory pointer location in the VIC chip. Also, you must tell the screen editor where the screen has been moved by POKEing the high byte of the starting screen address into location 648. Then warm start the system by either holding the run/stop and restore keys down or by typing the command: SYS 65234.
10.Q: Where does RAM start on the VIC 20?
A: RAM starts at 4097 decimal on the VIC.
