Nuevo Firmware.release 210330
https://github.com/mist-devel/mist-bina ... r/firmware
Nuevo Firmware.jorsus escribió:firmware_210618
- Compiled in thumb mode
- Fix a nasty long-standing buffer overflow in Minimig menu code
- 4 IDE drive support on Minimig (need IDEFix/ATAPIMagic)
- INI config format for Minimig (last time it has to be recreated)
- PCECD fix for playing the last track
- VHD= in ARC file
- And some other minor updates
SE mode
The core automatically switches to Macintosh SE mode, when an SE 256K ROM is used as the ROM file. The changes in SE mode:
The bigger ROM supports some new features
SCSI speed is increased
ADB used as a keyboard and mouse interface
The parameter RAM size is 256 bytes
Second microdrive support added. Games that require MDV2_ support, like "QL Pawn", are now supported.
Selectable ROM added
Games/Software moved to "QL Software Collection" on archive.org
